Motorcycle.comBikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
Old 12-18-2007   #1 (permalink)
Favorite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Unhappy Final drive Drain Plug
Met a fellow Rocketeer today.We got talking about pros and cons etc, he was telling me when he drained the oil from the final drive unit and was retighting the plug/screw it broke off.I told him about the trouble i had with the exhaust and manifold bolts.He said the dealer has replaced alot of drain plugs due to the fact people over tighten them . If by chance this should happen to me is there an up graded bolt or replacement bolt that is stronger. I believe it also comes wih a magnet attached to it...thanks in advance....Rick
TRIIICK is offline   Reply With Quote
Old 12-18-2007   #2 (permalink)
Count me in as one of those that twisted off the drain plug head. I have not yet replaced it and left it in, overtightened. I just pump out the old oil.
Ugarte is offline   Reply With Quote
Old 12-18-2007   #3 (permalink)
Favorite Bike: 2006 Rocket III Classic
Pig9r's Avatar
The bolt is hollow and has a magnet pushed in it, so it snaps easily. Follow the recommended torque rating closely or replace it with a regular bolt. If yours is stuck you should be able to push the magnet up a bit and get a bolt extracter to bite and turn it out.
Old 12-18-2007   #4 (permalink)
So there is "replacement" for "displacement"......lol I wonder if it's possible to get a stronger magnetized bolt. I replaced a speedo sensor on the RK after 5 years and the magnet was loaded with fine metal filings. Maybe a machine shop could mill one out...?
Final Drive jfcroni The Rocket Science Forum 4 07-09-2007 12:31 PM
Final Drive Recall Rocket_Rider The Rocket Science Forum 2 09-11-2006 10:58 AM
Rear drive drain plug Ugarte The Rocket Science Forum 9 08-02-2006 02:54 PM
Final Drive Number four! BIKERDICK The Rocket Science Forum 9 12-19-2005 08:14 AM
More thinking out loud: Final drive question, why not Belt drive or Shaft drive? rudebwoy85 Speed Triple Forum 10 11-07-2005 09:13 PM
