Old 10-14-2007   #1 (permalink)
Tps Sensor
Can someone tell Me if you can test sensor? My engine won't idle down at times in 2nd or 3rd and never idles as fast as it should .Most of the time it idles about 5-550 also surges in 2nd or 3rd Thanks
Harold
Harold is offline   Reply With Quote
Old 10-14-2007   #2 (permalink)
Favorite Bike: Triumph Rocket III Classi
Other Motorcycle: Honda VTX 1300R
R3 Idle Speed?
What is the standard idle speed of the R3? My 2006 idles between 8 and 900 rpm. Would like some input if possible.
T-Rex is offline   Reply With Quote
Old 10-14-2007   #3 (permalink)
Favorite Bike: 2006 Rocket III Classic
Pig9r's Avatar
Idle on the new tunes is set at 820. If you have tuneboy you can use the reset ISCV feature to set the TPS voltage. If you don't this is a good guide. http://www.triumphrat.net/the-rocket...highlight=idle
Old 10-15-2007   #4 (permalink)
Wink
I have used the process at the above link for over two years..Its not as complicated as It seems,and works great..You might have to stay with the throttle for 30 seconds on a cold morning but I can handle that.. Jack
busajack is offline   Reply With Quote
TPS Gone- What a difference!! CAPTDON Twins Talk 65 01-14-2008 12:59 PM
TPS & Shimms? webonnielad Twins Technical Talk 2 08-26-2007 02:24 PM
TPS and BC ECU SCCTrim Twins Technical Talk 48 04-30-2007 09:27 PM
TPS? mikeinva Twins Technical Talk 7 04-03-2007 09:29 PM
TPS Sensor Removal ! WA53JHO Twins Talk 23 09-12-2005 08:26 PM
