TuneBoy Install/Review - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-10-2007, 08:00 PM   #1 (permalink)
Chi-TownRocket's Avatar
My tuneboy came today and I immediatly openened it up and plugged her into the bike. I got through most the install and then realized that once you make contact with the ecu on the R3 you need to email the ecu number to the vendor in order to get the software key. I was somewhat disappt at this because it said it could take up to 24hrs. I immediatly emailed newbonneville.com with the ecu number which is needed in order for me to get the key to use the software. 15 minutes later I check my inbox and the key is there! Holy snikeys that was fast!
I then disabled the 02 sensor, corrected the speedo and loaded the 20050-2 tune. Holy snikeys again! Very easy to use and everything worked perfectly. I started the bike and it sounded and smelled different! The idle was lower and smoother and that slight burble here and there is gone!
I then rode the bike (even though it's low 40's and cloudy here today) and holy snikeys again! I hit it hard in first and confirmed that this bike has MORE power! Shifted into second hard and the front wheel came up about 2 feet! This thing is pulling like a fire breathing dragon that was just neutered! BTW the popping and gurglin on decel is gone!
It is truly worth every freaking nickel! I would love to ride a stock rocket back to back with mine. It has to be a night and day difference.
Overall very happy with the tuneboy and the service at newbonneville.com.
This really is the way the rocket should have come from the factory!
07 Rhodesian Rocket
TOR pipes/bypass and TuneBoy 20050_3
K&N Pod Filters under the BearClaw
"HDKILA" License Plate
Chi-TownRocket is offline   Reply With Quote
Old 10-10-2007, 08:45 PM   #2 (permalink)
If you want a side-by-side comparison, download one of the factory tunes. Load it, ride it, load the 20050-2 tune and ride it again. Switch back and forth all you want.
3ngin33r1 is offline   Reply With Quote
Old 10-10-2007, 08:47 PM   #3 (permalink)
Good Point. I guess the real test would be to race against a stock bike. The butt dyno is never as accurate LOL.
07 Rhodesian Rocket
Old 10-10-2007, 08:53 PM   #4 (permalink)
Neither is the rider you are going against. Clock yourself, it's not as exciting but more accurate since the rider will always be the same, you.
Glad to see you got your TB and had a good experience with newr3.
Old 10-10-2007, 10:48 PM   #5 (permalink)
My plan is to go to the track and try several tunes in the next two weeks.
07 Rhodesian Rocket
Tuneboy install time? And ECU question. PROMOD1385 Speed Triple Forum 9 07-13-2007 06:36 PM
Rookie Clutch install & Review mutineer Twins Talk 14 07-07-2007 06:18 PM
Need to know whats involved with tuneboy install glw The Rocket Science Forum 2 05-02-2006 11:24 PM
Which review is right?!? FF3 Sprint Forum 9 10-26-2005 02:08 AM
05 ST review Sprint Forum 13 02-25-2005 12:43 PM
