Motorcycle.com
Old 08-29-2007   #1 (permalink)
Newbie
Other Motorcycle: Triumph Trophy 1200
Drive Shaft Spline on RIII
My RIII has 17,700 miles on it and the drive shaft spline has split. Triumph is replacing the spline and other components damaged. The issue may be lack of grease on the spline. Not sure if this will be widespread or an isolated instance but just wanted to give other owners a heads-up that this may be an issue.
droche is offline   Reply With Quote
Old 08-29-2007   #2 (permalink)
hey dr...where is there grease required in the layout of the shaft drive? Isnt both ends bathed in oil?
is this a different problem to the usual shaft thrust bearing going blow up?
Iceman9 is offline   Reply With Quote
Old 08-30-2007   #3 (permalink)
Newbie
Driveshaft spline
Iceman, ya got me. Unfortunately I am not up on the mechanics of these things. All I can tell you is what the dealer told me: The spline split. There is no requirement by Triumph to grease the splines as other makes with similar splines do, however, according to them, the RIII spline is set up to do so. The dealer said they are going to grease my spline and all other splines on RIII's that they service. I don't know what Triumph is going to say.
I would guess that this is a different problem than the shaft thrust bearing since neither the dealer nor apparently Triumph had ever heard of this happening before.
Shaft Drive Bicycle nick_t Biker Hang-Out 2 10-25-2007 08:49 PM
Shaft drive? dazco Twins Talk 20 12-17-2006 02:06 AM
Chain vs Shaft drive hawkeyejohn14 Sprint Forum 16 01-04-2006 01:25 AM
More thinking out loud: Final drive question, why not Belt drive or Shaft drive? rudebwoy85 Speed Triple Forum 10 11-07-2005 09:13 PM
Shaft drive on new ST foggydewhearst Sprint Forum 10 08-14-2005 04:51 AM
