Fine tuning with TuneBoy - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-20-2007, 03:19 PM   #11 (permalink)
Hornblower's Avatar
Originally Posted by Pig9r View Post
Don't go by the values in the map because they are going to be different for each cylinder. Just make % changes based on the shaded areas (yellow 10% pink 15%). It doesn't have to be exact either, those were just the areas that Wayne from Tuneboy recommended.
I started with 5% and 10% then went up from there. Some have gone as high as 25%.
A quick way to do it is highlight a block of the area you want to change and hit F8. Then you just have to enter the % you want to change. Make sure to do it for each of the L1, L2 and L3 maps.
If you still have problems, pm me your email and which tune you are using and I'll send you a tune with the changes made.
Thanks Pig9r--You can tell I'm a newbie, can't you? Anyhow, I'm running the 20050_3 tune right off the TuneBoy website. So, if you don't mind I would love to just PM you, which I'll do right now, and get you to send me the tune with the changes already made. No sense re-inventing the wheel here...Thanks again-Ken B.
'07 Speed Triple
Hornblower is offline   Reply With Quote
Old 08-20-2007, 03:27 PM   #12 (permalink)
Hornblower's Avatar
BTW, Pig9r, where can I find a listing of the F key functions, like the F8 you mentioned for entering percentages? Thanks-Ken B.
'07 Speed Triple
Old 08-24-2007, 11:05 PM   #13 (permalink)
oxygen sensor
I am using the M18 plug with a metal washer not fiber. Anything other than metal with not hold the vibration and heat and keep a tight seal. You can use "Victor" muffler mender on the bolt to make an air tight seal that won't burn away!
rockenrobert
gotta see the world, it will only take a minute
rockenrobert is offline   Reply With Quote
Old 08-25-2007, 10:49 AM   #14 (permalink)
Hornblower's Avatar
rockenrobert
Yeah, I found out about the fiber washer the hard way. It lasted about 5 miles and blew out. I replaced it with a brass washer and I also coated the threads with anti-seize. That seems to be working OK.
'07 Speed Triple
Old 08-28-2007, 03:21 PM   #15 (permalink)
M18 plug
If you use the above plug you will need a metal washer. Thats the only type of washer that will stand up to the heat and vibration in that location. You will need to seal it tight "muffler mender" by victor. A little dab will do ya, around the threads. Other-wise you'll have an exhaust leak and more back-fireing.
rockenrobert
Old 08-28-2007, 03:28 PM   #16 (permalink)
Red face all ready posted on this I guess
Should read all before posting, I posted on this all-ready!
Posting on too many forms I quess.
rockenrobert
Where was the fine print? Whisperinsmith Biker Hang-Out 17 12-12-2007 09:49 PM
A fine motorbike...indeed Nochicanes Sprint Forum 10 12-09-2007 08:34 PM
FINE! You win! dblhelx Speed Triple Forum 12 06-19-2007 05:13 PM
Freak fine tuning Swordymon Maintenance & Workshop Talk 2 09-07-2005 11:44 PM
