Removing front axle-HELP
Alright, what can I be doing wrong? I loosened the 2 pinch bolts and finally found a large hex wrench that would fit into the axle socket. I have pounded on that thing and it wont' budge. Surely, these wouldn't be left-hand threads, would they? I even tried hammering in a screwdriver to spread the tangs apart and that didn't help either. This would be the first time this axle has been removed but I didn't expect it to be this tight. Also, have you found it necessary to remove the calipers in order to remove the front wheel? Thanks for any suggestions. --Ken B.
'07 Speed Triple
