Gear lever shaft - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-02-2007, 08:34 AM   #1 (permalink)
Can anyone share some advise on how much trouble/time to change gear shaft due to fall. Shaft snapped aprox 14mm out from engine case. :???:
revhed is offline   Reply With Quote
Old 07-03-2007, 10:21 AM   #2 (permalink)
Bummer! If you would have dropped it on the other side, I'd be able to help you out. I have a brake pedal sitting in my garage.
<center><big><font color=blue>DISCO LIVES</big></font color=blue>
</center>
Disco is offline   Reply With Quote
Old 07-06-2007, 08:46 AM   #3 (permalink)
I have heard of this before. The motor has to be removed from bike and engine dismantled. It won't be covered by warranty and will run into thousands. you say there is 14mm still protruding. i would be tempted to see someone who welds alloy and see if the broken bit can be welded back in place.
Good luck.
Go Hard or Go home!
Mav68 is offline   Reply With Quote
Gear Selector Shaft Oil Leak dart330 Sprint Forum 10 08-21-2007 05:27 PM
Gear shifter shaft removal dat Twins Technical Talk 3 06-11-2007 10:41 PM
T'bird gear shift shaft oil seal Tbird900 Hinckley Classic Triples 3 05-14-2006 06:17 PM
Oil leak at gear lever shaft TorqueyT Tiger Workshop (archive) 4 11-20-2005 05:22 PM
Bent gear change shaft Maintenance & Workshop Talk 0 09-28-2004 03:27 PM
