EPG Moto
Trident-Exhausts.comSportbikeTrackGearEPG MotoMotorcycle.com Classifieds!Riders DiscountBritish Motorcycle Gear
Old 06-29-2007, 10:24 AM   #1 (permalink)
Favourite Bike: soon a "97" Tiger
jthursby's Avatar
Hi guys, has anyone done an install on a Rocket of this horn?
http://www.casporttouring.com/store/merchant.mvc?Screen=PROD&Product_Code=Stebel11135& Category_Code=new
If so where and how did you mount it?
Pics would be helpful.
Thanks,
Jim T.
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.
Benjamin Franklin
jthursby is offline   Reply With Quote
Old 06-29-2007, 11:21 AM   #2 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
http://www.r3owners.net/showthread.php?t=1040
http://www.r3owners.net/showthread.p...hlight=strebel
I think you could mount it just about anywhere. I have one on my truck and didn't even need a relay.
[ This message was edited by: Pig9r on 2007-06-29 10:22 ]
Old 08-06-2007, 04:31 PM   #3 (permalink)
Stebel Horn Mount
It fits great behind the lh sidepanel with a short strip of steel to attach it to one of the adjacent frame bolts, you'll see them easy enough. The horn will fit just in the space below the 3 relay bank.
You will need to plug the relay to the original horn wires under the tank by pulling them from the horn on the steering and routing them back under the fuel tank.
Run a 20 amp fused wire from the positive battery terminal to the relay and another to the Stebel horn from the relay, the final connection is from the Stebel horn to the negative terminal on the battery or a good earth.
The current in the original horn circuit is not heavy enough to power the Stebel which is why you will need the relay on this particular machine.
Follow the circuit diagram which comes with the horn and you will find it's the same. I just can't remember which terminals I connected to which wire.
You will need about 2 metres of 20 amp wire, 4 x 15 amp female spade connectors. 2 ring terminals to fit the battery wires, a 20 amp inline mini fuse holder and a soldering iron. I tried crimp connectors and they will break.
Mine works great, very slightly dulled by the sidepanel but still deafening
AndyS4 is offline   Reply With Quote
Old 08-06-2007, 08:48 PM   #4 (permalink)
Favourite Bike: '05 Rocket
LukeSkyWalker's Avatar
fog lights present?
With the description you described, I have that space already occupied with the Triumph fog lights. Will I still have room?
Luke
LukeSkyWalker is offline   Reply With Quote
Old 08-06-2007, 09:33 PM   #5 (permalink)
Mounted mine behind the left cover as suggested above, follow this link to my description and pictures
http://www.r3owners.com/viewtopic.ph...ht=stebel+horn
biker1059 is offline   Reply With Quote
Old 08-11-2007, 11:06 AM   #6 (permalink)
I too mounted mine under the LH side cover, but I took it one step further: I wired the original horn in with the Stebel. They both go off at the same time!! IT'S LOUD!!!!!! (I like it that way)
PriorityOne is offline   Reply With Quote
Stebel Horn Pattern up to give away jeffro Sprint Forum 9 04-21-2008 05:05 PM
Stebel Nautilus Horn on Spint ST cricket1 Sprint Forum 27 03-15-2008 11:27 PM
t-100 stebel horn install Geoff Twins Talk 1 07-04-2007 11:16 AM
Stebel horn install question thefly Sprint Forum 2 06-08-2007 10:33 AM
Stebel Horn Mount biker1059 The Rocket Science Forum 14 10-16-2006 06:58 PM
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
