aftermarket exhausts - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-20-2007, 10:05 PM   #1 (permalink)
doncuddy
I am considering aftermarket exhausts for my 2006 rocket classic. Far too quiet for such an aggressive and awesome muscle machine. Would like some input on all the different makes out there. Have done some research and am familiar with the most common names---ie (jardine--mad dogs --tors). Are there many others out there of any account and quality? Somewhat familiar with things to be considered. Need for a Powercommander-- and retune codes. Not much of a mechanic. Interested mostly in improved sound--not necessarily "harley" loud, but I'd like people to know I'm coming. Improved power would be a side benefit as far as I'm concerned since my stock bike has far more power than I'm used to. Are other "performance" upgrades recommended in conjunction with pipes--ie air filters?
Old 06-20-2007, 11:45 PM   #2 (permalink)
you might consider these, due out with in the month. 153 hp/156 lbs torque. 304 stainless steel through out. double ceramic coated in various colors. run 300 degrees cooler than any steel exhaust. various muffler options and sound bitchen without the jardine resonance headache.
travelguy is offline   Reply With Quote
Old 06-20-2007, 11:46 PM   #3 (permalink)
ps , patents pending.
Old 06-21-2007, 01:36 PM   #4 (permalink)
Favourite Bike: 06 Rocket, "Lucy"
rndtaylor's Avatar
Okay. What are they?
Where do I find them?
rndtaylor is offline   Reply With Quote
Old 06-22-2007, 04:36 AM   #5 (permalink)
Why that Travelguys Predator exhaust :-D
shiver is offline   Reply With Quote
Old 06-22-2007, 04:51 AM   #6 (permalink)
correct amundo shiver.. the thought of anyone paying 1000-1100 for those crappy jardines like i did just kills me.
Old 06-22-2007, 08:58 AM   #7 (permalink)
Might have to get me self a set of your then :-D
Old 06-22-2007, 12:12 PM   #8 (permalink)
Hornblower's Avatar
I love the look of these headers slanting back but my concern would be heat, double ceramic coating not withstanding. It is my understanding that the reason for the headers pointing straighter down is to keep the hottest part of the pipes away from your legs. By slanting the pipes back, as shown in the picture, the hottest part would be right under, and very close, to your legs. If it weren't for that little problem, I would jump on this approach. --Ken B.
'07 Speed Triple
Hornblower is offline   Reply With Quote
Old 06-22-2007, 10:43 PM   #9 (permalink)
sorry to say hb you are way off base. triumph et al run them down because it's easiest. i'll have to check but mine probably run tighter to the engine than even the stock. they are no where near your legs.
these being stainless steel do not produce radiant heat like ALL other exhausts out there. jars on my buddys bike temp'd at 650 degrees even with their so called ceramic. mine bare ss are 250-275. yes that is correct without even double ceramic coating them which should drop it another 100 degrees.
if you check on the review "jimmyrocket" on r3owners.com did on my pipes you will note that you can bring your hand so close that before you feel heat you will touch the pipes. having had crappy jars i know that 2-3 inches is the closest before your hand starts to hurt.
might i suggest you try researching why all nascar/nhra etc use ss exhausts and related components.
might i suggest also you wait abit till pig9r and others have their demo sets. you perceptions about exhausts for this bike is about to change.
[ This message was edited by: travelguy on 2007-06-22 20:53 ]
Old 06-23-2007, 07:48 AM   #10 (permalink)
hi travelguy,whats is the cost and will i be able get them hear in Australia ,looks great,any more photos
thanks mate
Stephen. :-D
stephenj is offline   Reply With Quote
Aftermarket Exhausts jeffro Sprint Forum 5 12-04-2007 12:25 PM
T100 aftermarket exhausts carthaqprfc Twins Technical Talk 12 05-08-2007 09:12 AM
2006 S3 Aftermarket Exhausts White214 Speed Triple Forum 24 05-03-2007 12:37 PM
What aftermarket exhausts are you running? markfly Hinckley Classic Triples 18 01-16-2005 02:02 AM
AFTERMARKET EXHAUSTS- WHICH TO CHOOSE? KingPonzio Sprint Forum 18 01-22-2004 12:25 AM
