On 2007-06-15 02:47, TRIIICK wrote:
Does anyone have the battery tender accessory wire permanently hooked up to the battery. I just bought the Gerbing heated jacket......a buddy of mine runs it off his RK battery and would like to do the same on the Rocket. My concern is reading other forums where the sensors might be effected..? Also is there a particular charger that is better or more compatible than the rest...thanks in advance Rick :???:
I have the Battery Tender leads hooked up to the battery with the connection that goes to the Tender under the left cover. I like the Tender. It works great on my car too.
Are you asking whether it's a good idea to connect your jacket directly to the battery? I don't see why there would be a problem unless the jacket requires some power conditioning, which if it did would be in the jacket, which is just a resistor.
