Heat from bike - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-04-2007, 07:02 PM   #1 (permalink)
I love this new bike but the one complaint I have is there is a ton of heat that comes off of it when I ride through town. I'm okay on the highway because the wind blows most of it away. Is there any kind of shield out there to keep from burning your leg from the heat coming off of it? :???:
Gossamer3129 is offline   Reply With Quote
Old 06-04-2007, 11:57 PM   #2 (permalink)
Long pants and chaps. No riding this bike in shorts. The Honda Valkyrie is called the Dragon due to the heat it puts out so this bike must be a fire-breathing demon from hell.
Jack_G is offline   Reply With Quote
Old 06-05-2007, 10:41 AM   #3 (permalink)
Do the Jardines have as much heat shielding as the stock exhaust?
dougl is offline   Reply With Quote
Old 06-05-2007, 10:49 AM   #4 (permalink)
Yes they have the same shielding. I'm not so sure it's just from the pipes I think alot come off of the radiator. I will have to try some chaps. I have always worn long pants. I don't know how people wear shorts while riding a bike.
Old 06-05-2007, 06:31 PM   #5 (permalink)
If you've already eliminated the catalytic converter by installing the Jardines and the correspondingly richer tune, you've likely done the single best thing you can do to keep the engine heat down. Making certain the correct tune is in and the fan is functioning correctly also helps. My '05 was a frickasee'er till I had the correct tune put in. Now it's merely hot.
I don't know how much difference chaps will make, given their design. I wear thick leather jeans and on a long trailing throttle situation (down mountain passes, etc), my upper right thigh still gets toasted.
Aren't the Jar's ceramic coated?
The bottom line is though you're straddling a car engine and there will be some heat.
RocketEd is offline   Reply With Quote
Old 06-06-2007, 02:00 AM   #6 (permalink)
I dont get it. 115 hot hear in valley, no pain on the leg. you boys must be pencil pushers, turn the AC off and get clamitized. you'll be fine.
Damaged is offline   Reply With Quote
Old 06-08-2007, 10:56 PM   #7 (permalink)
Favourite Bike: Bonneville T100
Other Motorcycle: H-D FLHRI
Extra Motorcycle: BMW G650GS
On some bikes it's no problem...until they put a leg somewhere it shouldn't be and flash fry meat on something that woulda been just a minor ouch if denim and/or leather had been between them and certain parts that get hotter than a skillet. Guys you see riding in shorts are the ones who haven't done that...yet
sbljr is offline   Reply With Quote
How much Heat? Jimbeamrye The Rocket Science Forum 4 10-10-2006 11:30 AM
heat zippythehog T3 Sport / Touring Forum 3 09-17-2006 11:58 PM
Wallmart $20 bike cover with "heat proof" lower... dazco Twins Talk 5 07-31-2005 01:19 AM
Engine heat kgeissler Sprint Forum 8 03-20-2004 10:01 PM
heat Maintenance & Workshop Talk 26 07-22-2003 01:49 PM
