BikeBandit
Old 02-25-2007   #1 (permalink)
I have had my Rocket 3 about 135mph and it seemed to have some sort of speed limit cut out. Has anyone else had this happen?
kingpinnh is offline   Reply With Quote
Old 02-25-2007   #2 (permalink)
Favorite Bike: 2006 Rocket III Classic
Pig9r's Avatar
Yep. Classics are limited to 121 mph and standards 136 mph. The speedo also reads about 6% fast. It can be removed though.
Pig9r is online now   Reply With Quote
Old 02-26-2007   #3 (permalink)
Favorite Bike: 06 rocket III classic
Other Motorcycle: 75 custom superglide
Extra Motorcycle: 66 T120 R custom
how does one remove the speed limiters' restriction? :???:
goodfellow
gregtharas is offline   Reply With Quote
Old 02-26-2007   #4 (permalink)
With Tuneboy. Speed and rev limiter.
dougl is offline   Reply With Quote
Old 02-26-2007   #5 (permalink)
are you sure pig?according to triumph factory,they are both the same engines.my classic will indicate 140 mph most times i go out on it :wink: my triumph dealer also agrees that the two models have exactly the same motor.well thats in the uk anyway
rambo is offline   Reply With Quote
Old 02-26-2007   #6 (permalink)
I'm pretty sure that my 2006 classic speedometer read 135mph! Has anyone ever found top speed with out the limiter?
Old 02-26-2007   #7 (permalink)
Pig9r's Avatar
Yes both engines are the same however there are tunes for the classic and for the standard models. The only difference being the speed limiter kicks in earlier on the classic tunes. To see it with your own eyes download tunedit program from tuneboy and compare tunes (it's free).
kingpinnh- could be one of two things, speedo error causes higher reading on your speedo or your dealer loaded a standard tune instead of the classic only tune.
I believe in all gears except 5th there is a rev limiter which lets you bounce off the limiter. In 5th it is managed by fuel cutoff. The fuel starts to cut just prior to 6300 RPMs, doesn't feel as abrupt.
[ This message was edited by: Pig9r on 2007-02-26 19:11 ]
Old 02-26-2007   #8 (permalink)
I'm pretty sure it has the standard tune, I was running with a Honda rune that claimed to be going 132mph, and I passed him. Thanks for the info.
Old 02-26-2007   #9 (permalink)
Pig9r's Avatar
What was a Rune doing in front of you in the first place?? :-D
Old 02-27-2007   #10 (permalink)
Pig9r- it was fun just toying with the Rune! I found the info on the tune boy. Thanks for the education.
ROCKET 111 Aussie_Jack The Rocket Science Forum 3 04-10-2007 06:59 PM
Rocket 111 Insurance in the UK robinw The Rocket Science Forum 3 11-05-2006 03:36 PM
Customising the rocket 111 step1 RAT - United Kingdom 2 09-19-2006 12:02 PM
longer cables for rocket 111 bobk The Rocket Science Forum 6 07-11-2006 05:00 PM
ROCKET 111 CHROME FOR SALE [SEE CLASSIFIDES] macmolly The Rocket Science Forum 1 11-25-2005 07:17 PM
