Old 10-03-2006   #1 (permalink)
Freddie
Ok I am new to this forum, I have a 2005 Rocket just took it out west and now it has 9,600 miles on it now, and yes the stupid Metzler tire had the belts showing. I can say you can get another 4-500 miles out of it. I put a new tire on it, Now this may only be coincidence, BUT 2 days later I have a squeaking noise. only when the clutch is engaged. If you go slow, the noise speeds up with the wheel speed. You pull in the clutch it goes away. let the clutch out and its there again. I put it up on a jack and ran it and no noise ? I give. any ideas ? I pulled the wheel off again just to look its not rocket science one nut and a bolt. nothing
Thank you
Freddie
Old 10-05-2006   #2 (permalink)
farrier
I have an 05 r-3 and mine makes that squeaking noise too I have 4500 KMS.on her know?
Old 10-06-2006   #3 (permalink)
Freddie
I droped it off at the dealer last night we will soon find out what it is. not to worry
Old 10-06-2006   #4 (permalink)
MikeRokkit's Avatar
That noise from the left side is from the Pelosi gear whining again. Just ignore it.
MikeRokkit is offline   Reply With Quote
Old 10-06-2006   #5 (permalink)
Freddie
no its a slow squeek taht speeds up with the wheel speed. unil you pull the clutch in then its gone. let the clutch out and its there again. Put it up on a jake and let it spin and its not there. ? its a mystery
Old 10-15-2006   #6 (permalink)
Lee
Moderator
Favorite Bike: Triumph Rocket 3 Graphite
Lee's Avatar
Do you have clearance all the way around? could the new tiere be making contact with the increase in revolutins?
Believe half of what you see and none of what you hear.
Lee is offline   Reply With Quote
Old 10-29-2006   #7 (permalink)
farrier
Hi guys I have a 05 R3 very happy with her but! I get a sqeeking noise coming from the left side in 1st and 2nd gear only for the 1st 10 to 15 min. of the ride and only when the bike is moving then it goes away after warmed up good. And she is getting harder to start when she's cold in the morning won't idle and runs very ruff for about 30 seconds or so.
Has anyone had this symtom.
Old 10-29-2006   #8 (permalink)
vegasclive
Me too on this except no tire change and 2k miles.
Be real interested in finding out what this is.
Thanks for the post.
Clive.
Old 11-01-2006   #9 (permalink)
I had a squeal on my left side that went away when the clutch was pulled. ONLY WHILE RIDING AT LOW SPEEDS.
I took it to my Triumph dealer and they knew exactly what it was. Within 15 minutes it was done and have not had the problem since. All I know is they pulled the rear wheel and greased the final drive splines. I know this sounds like bull but it fixed the problem. I hope this helps.
Like I said, I didn't believe it either but I haven't had a problem since.
Mike
miketango is offline   Reply With Quote
Old 11-01-2006   #10 (permalink)
I've got 16,000 Km on my Rocket. From the beginning, there was a bit of a clunk when you engaged and disengaged the clutch. The dealer told me that was normal - something about the clutch "locking in like a tractor clutch" so it wouldn't slip under the torque. I believed them! I also saw other reports in the forum about a similar sound, so I wasn't worried about it. A month ago I changed the rear tire. Before I re-installed the wheel, I added more grease to the spline on the driven flange. There was a little grease there, but it wasn't coating the teeth! The clunk was gone, and it hasn't come back in the 1000 Km I've done since. The squeak under different load/clutch positions might be the same thing - a lack of lube on the spline. Another possibility is the "cush drive rubbers". Power is transmitted from the driven flange to the wheel via 5 rubber blocks. Some of the grease from the flange will work its way onto the rubber. If the rubber is dry, it can squeak! A lot of the left side noise that various captains are hearing might be related to a lack of lube. It's not critical, and wouldn't be a wear issue, but the smoother and quieter everything is, the more chance of you noticing something else that is wrong before you are left stranded. I know my bike had the recall done before I got it. Maybe half the lube went away with the original drive, and the dealer didn't add any upon installing the new!
BC-Rocket
BC-Rocket is offline   Reply With Quote
left side low side swingarm damage? NathanielM Speed Triple Forum 10 09-12-2007 08:02 PM
Odd noise from left side of engine.... Grigsby Twins Technical Talk 5 05-08-2007 04:00 PM
Left side damage Dirtbikemike Twins Technical Talk 6 08-21-2006 01:13 PM
Left side lean ? motomutt Classic, Vintage & Veteran 8 09-27-2005 09:46 PM
Left side lean? motomutt Twins Talk 1 09-20-2005 02:22 PM
