There were some posts a long time ago about similar problems. They were due to poor connections and/or moisture. The fix was to unplug, clean as necessary, put some Vaseline or other water shedding sealant and plug things back together properly!
The fact that the lights are going out along with the tachometer suggests to me that it is a grounding issue! If the tach was defective, the lights should still continue to function if everything is wired OK.
BC-Rocket
