R-3 dyno jet power commander - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-18-2006, 08:20 PM   #1 (permalink)
Lee
Multi-Iron Butt Moderator
Favourite Bike: Triumph RIII Graphite
Lee's Avatar
Other Motorcycle: Honda Goldwing 2012 Red
Extra Motorcycle: Is it really ever extra..
This is a R3 question. I would like to know if anyone has installed the dyno jet power commander. Did you see a significant difference in power, speed anything.
The other question I had was if anyone has used a track to check the time and top end of the R3. I was wondering exactly what the top end might be. Thank you lee
Four Iron Butt Rides Todate....Will Be Working On Longer Ones In The Upcoming Year...Jersey Born and Raised........Texas run 1000 in 24 hours in April 2012
Lee is offline   Reply With Quote
Old 09-18-2006, 10:49 PM   #2 (permalink)
Favourite Bike: Hinckley Classics
vonbonds's Avatar
Tons of posts on the PowerCommander. Play with the search function for a bit to see if you can get what you need. The long and short of it is if you install a PCIII and get it setup by a dyno center you will notice the difference. Your mileage may vary as far as improved HP and Torque.
vonbonds is offline   Reply With Quote
Old 09-21-2006, 04:07 PM   #3 (permalink)
Favourite Bike: 2009 Victory Vision
Silverado57's Avatar
Other Motorcycle: 2008 Victory Vision
Brother, you are NOT allowed to squeeze any more power out of your Rocket without a note from home! :-D
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 09-26-2006, 05:24 PM   #4 (permalink)
What's the best milage anyone's gotten out of a Rocket? I know it's a question I should not ask, because with an engine that big it's gotta eat something.
Jon_jynx is offline   Reply With Quote
Old 09-26-2006, 05:33 PM   #5 (permalink)
vonbonds's Avatar
I think people with unmodified stock Rockets get the best mileage. I have heard 35-40mpg depending on the right wrist.
Old 09-27-2006, 07:52 AM   #6 (permalink)
Before I installed the TORs/cat delete and Power Commander I was getting over 39 MPG.. Now I average 35 MPG.. But the power comes on so much smoother, no popping on decel, and you can hear the motor run!..
Dave Arnold
'04 Rocket III
'00 Trophy 1200
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 09-27-2006, 09:46 AM   #7 (permalink)
Makes sense. The stock tune is lean so you must have added gas.
Where I live is about half highway half street. I've never gotten more than 34 mpg. With my Tuneboy dyno TOR/cat bypass tune, I get 32-33. After riding around downtown Reno during Street Vibrations, I got 30.
dougl is offline   Reply With Quote
Old 09-28-2006, 11:33 AM   #8 (permalink)
glw
Favourite Bike: Rocket III Classic
glw's Avatar
Other Motorcycle: 76 Bonneville
you seem to gain about 5 hp and lose about 5 mpg. (miles per gallon)
glw is offline   Reply With Quote
Old 09-29-2006, 07:07 AM   #9 (permalink)
LEE.. I had a Power Commander on with the Staintune pipes and had the bike tuned on the Dyno. I ended getting 142Hp at the Rear Wheel and around 150Nm torque (stock it was reading around 125Hp @RW), and a better throttle response but beware that when you put your bike in for a service the dealer will automatically throw a new or updated tune on the bike which will throw all this out the window. MAKE SURE IF YOU GO THIS TRACK YOU ASK THEM TO LEAVE THE TUNE ON THE BIKE THAT IT WAS DYNOED WITH!!
Eventually i went with Tuneboy and had the PCIII removed. I got even better figures and a better ignition map as well as the secondaries opened fully in all the gears including 1st and 2nd.
Hope this helps.
SteveRed..
He said... "Nobody needs that much power"
I said... "Who wants to be a nobody?"
SteveRed is offline   Reply With Quote
Old 10-01-2006, 08:53 AM   #10 (permalink)
Lee
Lee's Avatar
I have been averaging about 35-40 depending what kind of riding I have been doing. I went to new jersey and did as well as 40 mph. the problem comes into play when you feather the throttle. I can not help every once in a while to see how much she has. Lee :-D
Dyno Jet Needles BonnieBob Twins Technical Talk 5 02-11-2008 09:52 PM
Dyno Jet vs Thruxton needles pelle Maintenance & Workshop Talk 3 10-09-2007 12:55 PM
Dyno Jet Looking for Bonnevilles vitabrew Twins Talk 3 07-16-2005 10:32 PM
dyno jet kit for the 1200??? Turin Daytona Deliberations 13 06-22-2005 01:24 PM
