Trip counter question - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Ontario TourismMotorcycle.comHonda Powersports
Old 09-14-2006, 01:55 PM   #1 (permalink)
Just got the bike, was riding back from lunch today trying to reset the trip counter. Finally got it back on odometer.
How do i work the darn thing. It only turns counter clockwise, do i hold it or press it in or pull it out.
Denton, NC
Decibels are no substitute for velocity
www.dunringil.com
dunringil is offline   Reply With Quote
Old 09-14-2006, 02:46 PM   #2 (permalink)
You hold it, then press it in, then pull it back out... :wink: :-D
Regarding the trip counter, to set it to 0 just turn and hold it a couple of seconds.
Ugarte is offline   Reply With Quote
Old 09-14-2006, 05:43 PM   #3 (permalink)
Hmmmm. This is how mine works. Each time your turn it counterclockwise, it advances between 1st trip, 2nd trip, and total odometer. Hold it all the way counterclockwise on the trip and it zeros.
[ This message was edited by: dougl on 2006-09-14 15:44 ]
dougl is offline   Reply With Quote
Old 09-15-2006, 08:00 AM   #4 (permalink)
Do they all have a trip od? Mine had one but now that theyve replaced my guages, there doesnt seem to be a trip od anymore...
Ferret is offline   Reply With Quote
Old 09-15-2006, 08:39 AM   #5 (permalink)
Favourite Bike: '05 Rocket
LukeSkyWalker's Avatar
dunringil,
I had the same problem.
There is a tiny screw on the end of the knob.
That screw may need to be adjusted.
If I remember right, the knob turns clockwise.
When you are sitting on the bike, the knob rolls from front to back (toward the rider). Wouldn't that be clockwise?
When I had my issue with the trip, it too would only turn counter-clockwise.
I loosened the screw then tightend it and the knob then turned from front to back and cycled through the two trips and odometer.
Hope this helps.
Luke
LukeSkyWalker is offline   Reply With Quote
Old 09-15-2006, 08:43 AM   #6 (permalink)
What dougl said for mine.
RocketEd is offline   Reply With Quote
Old 09-15-2006, 08:50 AM   #7 (permalink)
dunringil,
I misspoke.
The trip does turn counter-clockwise.
Loosen the screw on the end of the knob and carefully turn it toward the front of the bike.
The trip will cycle for you.
Then tighten the screw.
Luke
Old 09-15-2006, 09:28 AM   #8 (permalink)
Favourite Bike: 2005 Rocket III
RidinSunshine's Avatar
You guys are terrible. Wasn't hard for this gal to work. Just turn and hold until it resets. See blondes are smarter than you think. :lollol:
REAL WOMEN RIDE TRIUMPH
FOR SOME THERE'S THERAPY FOR THE REST OF US THERE'S MOTORCYCLES
RidinSunshine is offline   Reply With Quote
Old 09-15-2006, 11:11 AM   #9 (permalink)
You got that right. We put our chaps on backwards half the time.
Old 09-15-2006, 11:15 AM   #10 (permalink)
You mean there is a front and a back on chaps?
Does the buckle go in the front or back?
I'm so confused!
Luke
Rev counter question jwhitehead Sprint Forum 0 05-30-2007 06:58 AM
I love my new trip- quick seat question halmul Speed Triple Forum 3 03-31-2007 11:10 PM
valve adjustment question, before trip sweatmachine Twins Technical Talk 5 10-15-2006 01:17 PM
Tachometer/rev counter question TillmanTillman Speed Triple Forum 0 07-27-2006 03:32 PM
Question about changing counter-sprocket NinjaRAT Sprint Forum 6 09-19-2005 10:13 AM
