What size are the rear shocks ? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-14-2006, 03:37 AM   #1 (permalink)
Beast-Rider
Hi guys I'm looking to replace the rear shocks for some 440's and would like to keep them the same size but what is the stock size? Also I weigh 190lb so should I go for standard or heavy duty and are these 440 shocks rearly that good?
Thanks
Old 09-14-2006, 06:34 AM   #2 (permalink)
Beast-Rider,
Plenty of postings on this subject. 12.5" is stock. A search on shocks will show you that most riders have gone with the standard in your wieght class. With all the beer I drink and closing in on 60 years, I'm a bit north of your wieght of 190 lbs. Unless you do a lot of 2-up riding, the standards appear to be the best bet. 90% of my riding is 2-up, so I went with the 12.5' HD's Progressive 440's and am real please with them. They made a big difference, especially going over those dam raised "bump-ups" that I encounter sometimes on the NYS Thruway (I-90).
At 5' 7", the 13" were too tall...I know because I tried them. Just that half inch made it so I couldn't get both feet flat down It cost me a little $$$, but I got Progressive to exchage them for the stock lenth of 12.5".
Ride safe,
Dick
BIKERDICK is offline   Reply With Quote
Old 09-14-2006, 09:55 AM   #3 (permalink)
Favourite Bike: Rocket III
Yes, buy the shocks. You won't need the HD option.
Find your favorite road bump and do a before and after ride. In my experience I was continually bottoming out the shock and the first 600 miles or so it was like not having a rear suspension. Replacing the shocks , I actually feel the rear suspension moving like intended.
You can also adjust the shock setting to 5 to improve the ride, and from another post I understand you can also just replace the spring on the stock shock. You do have options.
TallRocket is offline   Reply With Quote
Old 09-19-2006, 04:40 PM   #4 (permalink)
I'm a bit on the large side at 6' and 260lbs. I've fitted the heavy duty 12.5" 440's and had to wind them right back to their softest setting and... still wish I could wind them back more. Since I can't I'll stick to drinking beer and dodging salad. Go with the standard 440's
Radar is offline   Reply With Quote
Old 09-30-2006, 02:58 PM   #5 (permalink)
Beast-Rider
Thanks for all the info guys Have just received my 440's from over the pond and fitted them today. Went out on a bumpy lane and boy what a difference they defiantly soak up the bumps. I have them set on the lowest setting and seems fine to me but will look to set up as I go on.
Once again thanks for the advice
Old 10-01-2006, 03:31 PM   #6 (permalink)
So what did you get....
Jimbeamrye is offline   Reply With Quote
Old 10-02-2006, 11:42 AM   #7 (permalink)
Beast-Rider
I got 12.5 inch standard 440 as Dick suggested, stock number 440-4209C they are on the lowest setting and so far so good. Planning to tour Spain in two weeks so I may have to adjust them up a bit depending on how much luggage I take.
Thruxton Size Shocks on Bonnie drock003 Twins Technical Talk 4 05-19-2007 08:33 PM
Someone tell me about these rear shocks Psychlopath Twins Technical Talk 9 03-15-2007 10:11 AM
Hagon rear shocks/150 rear tire ROBD Twins Technical Talk 12 02-09-2007 04:38 PM
Thrux Rear Shocks vs. Bonnie Rear Shocks faffyface Twins Talk 1 01-24-2006 03:54 PM
Rear Shocks bcohen Twins Talk 2 01-15-2006 11:15 PM
