Brake Light? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-05-2006, 06:27 PM   #1 (permalink)
Roundman
Where is the relay for the back brake stop light? I checked the front relay and it's working fine.
As crazy as it sounds after the bike set for a little while the brake light will works fine. Until you use the back brake and them the light will stay on. :???: :???:
[ This message was edited by: Roundman on 2006-09-05 18:37 ]
Old 09-07-2006, 09:17 AM   #2 (permalink)
Are you sure the rear brake switch is working cleanly? If that's sticking on it would explain your problem.
________________________
___________________________
Nil Illegitimus Carborundum
SickNick is offline   Reply With Quote
NB FEK installed, brake light works no running light pbcurran Club Cafe' 9 10-25-2007 03:20 PM
Brake Light IN-OP Cynr1023 Maintenance & Workshop Talk 1 08-05-2007 01:25 AM
No brake light on '07 VWTim Speed Triple Forum 6 06-19-2007 03:54 PM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
Brake light - front brake Trudie Classic, Vintage & Veteran 8 03-16-2005 10:19 PM
