On 2006-09-06 15:41, VictoryDaveAZ wrote:
Bigern,
Where is this bearing cap you are looking for and what is it used for? May have a source for you.
The cap in question is used on the transmission output shaft to help clamp down a roller bearing on the end of that same shaft. The cases clamp down on two other roller bearings on the same shaft, but leaves the third bearing half exposed were it intersects the main driveline output gear. That is where the cap comes in. It's about the same size as a Chevy 350 piston rod end cap. If you've got a factory manual handy, look on page 5.5-5.6, there it shows removing the Transmission Output Bearing Cap. It is also shown on the illustrated parts page showing the case halves. It is shown right in between the case halves.
As far as the welding process, The guy is going to bolt it down the the case half and check for any distortions of the inner circumference as the process proceeds. This should help keep everything in line. I had thoughts of having one made out of billet, and still may after the cap is fixed, using that same cap as a templet. It may be my last resort short of buying a new set of cases.
Dave, if you don't have access to a manual, MSG me a fax number and i'll fax you a picture of the offending part. This part is manufactured completely seperate and sent down the assembly line to be matted with a set of cases. True, there may be some trueing up work that may need to be done for a perfect fit, but there is no reason why they can't grab one out of parts bin. Triumph won't even let me have on off a warranty or trainning engine. Thanks for the interest and suggestions of help. As always, the members of this Forum have been a great help!
: Bigern
[ This message was edited by: bigern2300 on 2006-09-06 16:27 ]
