i have changed some old Koni shock springs, the trick is to compress the springs without damaging the shaft, it can be bent under pressure, i convereted some old auto spring compressors and worked it a bit at a time....then tied big nylon ties around the springs on each side....it was ruff but did the job, just be careful as there is a lot of pressure and if it lets go stuff flys everywhere, might be better ot get someone to do it for a small cost...there professional are rigs built to do the job
