Old 06-04-2006   #1 (permalink)
Other Motorcycle: BMW K1200 R Sport
Just washed the Rocket and discovered that the upper mount of the left hand side bar/guard has snapped right off!!
I haven´t been even close to drop the bike and/or hittig something with it. Seems to be the weld that has cracked.
I will try to get a picture of it later today.
Any of you guys experienced the same??
Second best after knowing something, is remembering where You read it...
Rocket-tre is offline   Reply With Quote
Old 06-04-2006   #2 (permalink)
Old 06-04-2006   #3 (permalink)
These Triumph bars do tend to break, exactly as you describe it. Friend of mine has gone through 3 sets in less than 18 months. All 3 replaced under warranty. No question asked and no objection raised by the dealer nor by the importer. Suggest you pursue the same, that is free replacement under warranty.
Should the new set develop cracks as well (i.e. UNLESS Triumph has come up comes up with a reinforced design?) the alternative is to go for Rivco crash bars.
Best wishes Jamie
Jamie is offline   Reply With Quote
Old 06-04-2006   #4 (permalink)
Favorite Bike: 2006 Rocket III Classic
Pig9r's Avatar
How long ago did you purchase them. I thought that they upgraded them fairly recently with a heavier gauge of metal.
Old 06-04-2006   #5 (permalink)
I ordered them pretty early in 2005, but they were on backorder a couple of months, so I believe they are from, say, april 2005.
Old 06-04-2006   #6 (permalink)
Pig9r's Avatar
Maybe someone can confirm this but I thought the Triumph bars were beefed up compared to the earilier versions. Yours are under warranty anyway so you so get to find out for us if no one else knows.
Old 06-08-2006   #7 (permalink)
The dealer ordered new without hesitating and they arrived today. I will take some pics to see if there is a visible difference!
Old 06-10-2006   #8 (permalink)
Got a full set, but decided to only change the left side, since that was the one that broke and it was the "easy" side so to speak. Didn´t take any pictures because there was ABSOULTELY no visible difference between the old bar and the new. It was within a 1/10 of a millimetre the same thickness and everything.
The old bar had simply snapped, it wasn´t a weld that was faulty, the "ear" was cracked like a biscuit.
Anyway, I decided to cut out a small rubber bushing to install between the bar and the frame, perhaps that will eliminate some of the vibrations. :hammer:
Triumph engine dresser bars maxracing Twins Technical Talk 2 11-05-2007 11:26 PM
Engine Dresser Bars JP06t100 Twins Technical Talk 12 10-05-2007 07:49 PM
Engine Dresser Bars (Crash Bars) meyers_john Twins Technical Talk 10 12-17-2006 04:40 PM
Engine Dresser Bars JMV2006 Twins Technical Talk 12 08-02-2006 04:08 PM
Engine Dresser Bars eVol Twins Talk 16 08-01-2006 09:05 PM
