AdvanstarMotorcycleShows
Old 05-29-2006   #1 (permalink)
R3T
The bike arrived at the MC-Xpress at 2 PM today. One hour later it had been dyno tested. 138hp on the back wheel. The only mod on was D&D exhaust with the right program and Shell V-power fuel. Not bad!
Love the D&D by the way. Perfect finish and fit. Still, I have heard a RIII with a 3to1 exhaust and it sounded better then anything else. Might change while I’m at it (translation: If I can afford).
The position of the turbo has already been moved from in front of the back wheel to high on the right side. Not very discrete, but it will be closer both for the exhaust and for the pressured side, easy to fit the intercooler and no need for a return oil pump.
A larger turbo then the one was planed for in the beginning will be used. A small turbo will start loading earlier, but will restrict the gas flow. Since the beast has a fair bit of torque in low revs, it might be better if it can breath easier and wait for the turbo to kick in at about 3000rpm. If it don’t work well enough, it should be easy to change to the new Areocharger, as Dyehard suggested, once it is out and has been tested by someone else then me.
I hope to go up there next week and be able to show pictures and data.
Including a link to the turbo company. They have some nice stuff on their web site. Have a look at “records” and some movies of the madness.
www.MC-Xpress.com
To be continued...
R3T is offline   Reply With Quote
Old 05-29-2006   #2 (permalink)
looking forward to part 4
IceT is offline   Reply With Quote
Old 05-29-2006   #3 (permalink)
This is more exciting than American Idol :hammer:
SoccerRef is offline   Reply With Quote
Project PE175: Part 2, the rider's story AMA DirectLink News Room 0 08-04-2007 09:30 PM
Project PE175: Part one, the tuner's story AMA DirectLink News Room 0 08-04-2007 09:30 PM
Turbo project, last part R3T The Rocket Science Forum 23 07-11-2006 08:49 AM
High pressure turbo, part II R3T The Rocket Science Forum 5 05-23-2006 06:27 AM
Part of a continuing "project" UJMrider Hinckley Classic Triples 2 02-17-2006 08:52 PM
