Old 05-02-2006   #11 (permalink)
Some captains have complained of enough vibration to make their mirrors hard to see out of. I get just enough vib. to let me know I'm on a motorcycle, but not enough to shake the mirrors, even at 130 mph.
The more I love it, the more I like it!
http://f10.putfile.com/thumb/8/21522560434.jpg
wilbur-t is offline   Reply With Quote
Old 05-02-2006   #12 (permalink)
On 2006-05-02 09:24, davidhp57 wrote:
At 130 I can still distinguish the cops from the cages in my rearview mirrors.
Smooth as silk!!
Great picture. How did you hold the camera?
Seems really stable. I see you have a windshield. Do you have bags too?
dougl is offline   Reply With Quote
Old 05-02-2006   #13 (permalink)
At 130 I can still distinguish the cops from the cages in my rearview mirrors. Smooth as silk!!
With the Triumph 8-10% speedo error you're smooth as silk at 118 or 119 mph there! I gotta try a pic like that... but it's harder to do with no shield! Your goggles tend to start vibrating and doo-rags fly off at those speeds!
<center>
http://www.lost202.com/members/ej-sigs/usa.gif
Because Size DOES Matter
</center>
ejmoment is offline   Reply With Quote
Old 05-02-2006   #14 (permalink)
I hear so much about this speedo error, but every time I drive by one of those D.O.T. trailers on the side of the road that flash your speed at you, mine is dead on. My odometer seems dead on too when you check it against the interstate mile markers.
Old 05-02-2006   #15 (permalink)
The speedo error is off by a %, not a flat amount. Meaning, it is closer and less noticeable at 30 mph than it is at 120. As for the mile markers... LOL I don't think that argument will stand up in court! Try running it with a GPS once and you'll see.
<center>
</center>
Old 05-02-2006   #16 (permalink)
I compared my speedometer to my GPS unit and found almost no difference. The small differences I think were due to the GPS updating.
NightTerror
"When you change the way you look at things, the things you look at change"
Nightterror is offline   Reply With Quote
Old 05-03-2006   #17 (permalink)
Just held the camera in my left hand and pointed it at the speedo. It was even a little gusty. Practiced a couple of times at lower speed.
Of course you live in the mile high city so you have much less wind resistance...... :wink: .....lucky stiff!
Jeff
http://users.shomecom.com/~jeffrey/pics/flag.gif
TRIUMPH ROCKET III ( Latin: Holius Craptor)
Hondax is offline   Reply With Quote
Old 05-03-2006   #18 (permalink)
I've found that bike is quite stable but the turbulence is pretty bad, even with the windshield.
Old 06-08-2006   #19 (permalink)
Hey hlw3, I have the same concern with my Rocket. When the r's get up there & the speed increases, the vibration thru the entire bike makes me feel something is wrong. Not certain it is the same on all Rockets but some of us are not stating it is. I have a friend coming into town soon & I'm going to have him take a Rocket flight on mine to compair it to his, which he says is smooth.
Still worried, hope that a checkup at the dealer will find a slight adjustment need & the engine will smooth out.
Good luck to you.
rusty is offline   Reply With Quote
Old 06-09-2006   #20 (permalink)
Funnily enough I had similar issues re vibration at about 3000RPM, 120KMH. I pulled the clutch in and let the motor idle and the vibration was still there.
There was two things causing it,
1: Incorrect tyre pressures, I basically changed tyre pressures to reduce the vibration, takes a bit of fiddling but it does help, check results on the same piece of road.
2: Stock shocks, since putting the Ikons on, less vibration is transmitted to the bike
Seems to work no more vib issues
Ride it like ya stole it
BUMC
Ted1296 is offline   Reply With Quote
TR6R Engine - T100D Engine Northern650Twin Classic, Vintage & Veteran 7 01-17-2007 11:40 PM
S3 engine vs sprint engine S32k1 Speed Triple Forum 4 11-19-2006 08:15 PM
Question about Engine oil / Engine Covers on a Bonnie..... Brk4moose Twins Talk 6 05-31-2006 09:48 PM
Age of engine from engine number nav18tor T3 Sport / Touring Forum 4 05-26-2006 01:49 PM
motorcycle engine oil v.s. Auto engine oil delroc The Rocket Science Forum 24 04-18-2006 08:31 AM
