Exhaust question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-27-2006, 12:07 AM   #1 (permalink)
What happens if your take the stock pipes off and remove the cat, and then put the bypass and TORs on without changing the tune in the ECU?
Thanks.
-trey
-trey way
-poulsbo, wa
hlw3 is offline   Reply With Quote
Old 04-27-2006, 06:44 AM   #2 (permalink)
You make more noise and wake the butcher's dog! davo
Only a biker knows why a dog sticks it's head out of a car window
Aussiebikerdave is offline   Reply With Quote
Old 04-27-2006, 01:50 PM   #3 (permalink)
Favourite Bike: 2005 Rocket III
RidinSunshine's Avatar
:lollol: :roflmoa2:
REAL WOMEN RIDE TRIUMPH
FOR SOME THERE'S THERAPY FOR THE REST OF US THERE'S MOTORCYCLES
RidinSunshine is offline   Reply With Quote
Old 04-27-2006, 02:17 PM   #4 (permalink)
Yeah, you'll backfire a bit without the tune... and you'll backfire a bit with the tune.
I didn't see much difference and might not have done the re-tune. I'd saved the $50 the dealer charges.
<center><big><font color=blue>DISCO LIVES</big></font color=blue>
</center>
Disco is offline   Reply With Quote
Old 04-27-2006, 06:30 PM   #5 (permalink)
If you install the cat-bypass and TORs without a richer tune your taking a chance of running the engine lean and doing damage. Lean burn engines run hot.
I had 3 K&Ns, cat-bypass and TORs with the 20056 tune. When dynoed, I was informed by the tech I was on the lean danger line. If I installed the richest tune, 20054, I would have been OK.
At least find a dealer with an exhaust sniffer unit that will detect the fuel/air mix and have it checked. If your cooling fan comes on often that is also an indicator. So is a gowing red exhaust manifold.
50 bucks for a richer tune is a lot cheaper than a blown engine.
Ride hard, die old.
drtim is offline   Reply With Quote
Old 04-28-2006, 04:45 AM   #6 (permalink)
I would say you would be best served by putting on a Tuneboy modified tune and you will really be getting the best out of your bike with the new set up!
SteveRed..
He said... "Nobody needs that much power"
I said... "Who wants to be a nobody?"
SteveRed is offline   Reply With Quote
Exhaust Question HandleOnTheRight Speed Triple Forum 5 11-22-2007 03:10 AM
Exhaust question feliz Sprint Forum 7 11-12-2006 01:04 AM
Exhaust question HotSkeete Speed Triple Forum 1 10-05-2006 12:11 PM
Yet another exhaust question. Skiandclimb Daytona Deliberations 1 06-11-2006 06:42 PM
Yet another exhaust question? Dogma Sprint Forum 2 12-06-2005 01:53 PM
