PCIII USB - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-25-2006, 09:38 PM   #1 (permalink)
Newbie
Just installed a PCIII USB on my 05 Rocket. I have TOR pipes and K&N air filter , cat bypass. It was sent with 510-003 tune, it idles better and runs cooler, I have low,mid range, and high all set at zero. Anybody have any advice on fine tuning one of these?
bdrocket is offline   Reply With Quote
Old 04-26-2006, 07:37 AM   #2 (permalink)
Toystoretom's Avatar
Here is a thread that has a lot of info on it...
PC III
The PC III is easy to use and if you have a lap top or a computer in your garage its fun to experiment with. If your modifications don't work out simply change it back. The accelerator feature is a must!
Also... there is a primer on the CD that tells you how to work with it...
Tomo
Triumph Rocket III
Toystoretom is offline   Reply With Quote
TORS and PC3 USB... Mesoam Speed Triple Forum 1 10-03-2006 05:45 AM
USB Tuneboy ! BigVinny Daytona Deliberations 9 07-27-2006 01:32 PM
USB Tuneboy ! BigVinny Sprint Forum 3 07-23-2006 10:36 AM
TuneBoy...USB TripleTrouble Speed Triple Forum 5 08-13-2004 07:42 PM
