I just removed my rear wheel and had the tire replaced. When I took the wheel off the drive hub was not secured in by the big circlip as referenced by the Triumph manual. It just dropped out of the wheel.
Now I had my rear end replaced under the recall but I cannot see why they would have to remove that circlip. Has anyone else removed their rear wheel and not found that circlip? Is it really needed or just there so the hub stays with the wheel when you remove it from the bike?
Thanks for the input in advance
