Why would you even ask about weight?
No...seriously. What were you thinking? That after less than two years' service on this machine, any of us would suddenly be smarter than the factory about what weight of oil to run in it???
C'mon, give us a break. Last thing this world needs is another looney oil thread. :razz:
Like our moderator says, I wouldn't be afraid to run 10W-40 synth in it all year, either. This is a big, lazy, understressed engine.
It's also water cooled--meaning, unless you lose your coolant (in which case you've got other problems to fret about)
your OIL is going to be running within a few degrees of the same temperature, summer or winter! That's why most of us end up with the sort of results Kilibreaux reports.
From a protection standpoint, that's why it doesn't matter whether the "high" side of the weight number is 40 or 50. If anything, the thicker viscosity just represents additional power loss and waste heat production.
The low-temp number will be relevant to cold starting, of course; but I can't see any reason to ever go over the 15W recommendation.
Triumph probably put the two chioces in there just in case you are in Lizard Flats Kansas and they only have one certain weight to choose from
That must be it. Especially since, in some parts of Kansas, we have to ride over to the next county to even see Lizard Flats on the distant horizon.
:-D
