On 2006-02-25 17:33, Toystoretom wrote:
Ta?? :-D
Ha...
Tomo
Tomo, I once had one of your countrymen over-hear me use the term "ta" and asked me what the in the hell does that mean! If he'd had any lick of sense he would have worked it out from the context in which it was used as I'm sure you have already done!
Basically the word "ta" is a quick and easy way to say thankyou and is usually one of the first four words every baby learns after Momma, Dadda and NO! Like, give me the dirty biscuit that you have been scrubbing the floor with that you're just about to swallow... ta-ah, meaning thankyou, spit it out please!
Hope this tiny portion of English (and Australian) culture has made your day Tomo.
Sorry, I digress, did someone mention torque settings? Actually I don't know the figures, I just do it by feel although this wont help much if you are new to mechanical things. Try this, tighten drain plug with your fingers until firm. Using a 3/8" drive socket with a SHORT handle, give it a little turn and then one more small tweek. Not very scientific I'll admit so just remember that you are tighening a steel drain plug into a soft aluminium sump cover so err on the side of "easy does it". Davo
[ This message was edited by: Aussiebikerdave on 2006-02-26 00:56 ]
