oil change on rocket - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 13 (permalink) Old 03-11-2006, 02:36 PM
rickwats
Here is a link to a pdf file ... which is the 2005 triumph rocket 3 owners manual
It shows the shows the correct location of the oil sump plugs (which are in a different position to 2004
rockets) on page 57.
And it shows under the tyres section that Bridgestone now supply officially approved tyres for the rocket 3 on page 98
http://www.triumph.co.uk/media/RocketIII(1).pdf
keywords: oil change rocket 3 2005 sump pan plugs location
post #12 of 13 (permalink) Old 03-11-2006, 09:55 PM
MikeRokkit's Avatar
You better check out Tomo's post on 2/17 about changing oil. Good stuff!
Mike
MikeRokkit is offline
post #13 of 13 (permalink) Old 03-12-2006, 07:43 AM
rickwats
I have finally changed the oil my my rocket. (using the 2005 owners manual to get the location of the 3 sump plugs )as above.
Question: I have hand tightened the new oil filter.. Is this sufficient .... to get the required torque setting of 10NM ?
thanks
rickwats
First oil change, gear change still clunky M2MG Speed Triple Forum 21 09-27-2012 02:01 AM
sprint 05 verses Rocket do I change ? garby The Rocket Science Forum 3 07-09-2006 06:24 PM
oil qty for oil & filter change??? Cheapbastard Speed Triple Forum 8 03-29-2006 10:56 AM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 09:43 AM
how much oil is safe after oil change with filter shedds Hinckley Classic Triples 0 04-18-2004 08:39 PM
