Hi, if the bikes sitting for a while i would get an Ulitma battery charger and leave it connected. take the plugs out and squirt a little WD40 down the bores and put the plugs back. put a cover over the bike, something that doesn`t absorb moisture. if its a stone, concrete floor put an insulator ( wooden blocks ) under the tyres and side stand just to keep it the same hight. theres no need to keep starting it up as your just making more condensation in the engine, you need a good run to clear that.
hope this helps !!
KK
ps make sure the anti-freeze is OK !!
pps the WD40 or similar is to stop the bores corroding from moisture in the bores.
[ This message was edited by: KuzzinKenny on 2006-02-19 09:00 ]
