Starting Problems - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleMotorcycle.comHonda Powersports Ontario TourismSportbikeTrackGear
Old 02-15-2006, 07:20 PM   #1 (permalink)
Sorry if this has been covered before but I did search...
Lately, my rocket doesn't always want to start. I push the button and nothing.
I've tried putting the kickstand up and down to see if the sensor is to blame.
I've turned the power on and off using both the key and the kill switch.
In the end, it always starts but it is getting frustrating. Especially when there are other bikers around.
I'm thinking that there has to be a sensor somewhere sending a signal that it's not OK to start.
Any ideas?
Thanks
[ This message was edited by: Disco on 2006-02-15 17:20 ]
<center><big><font color=blue>DISCO LIVES</big></font color=blue>
</center>
Disco is offline   Reply With Quote
Old 02-15-2006, 07:58 PM   #2 (permalink)
The Rocket also has a clutch kill switch...check that one...it may be loose.
Ugarte is offline   Reply With Quote
Old 02-15-2006, 09:07 PM   #3 (permalink)
Also check your battery connections. Make sure they are clean and tight.
tmiller11147 is offline   Reply With Quote
Old 02-15-2006, 09:47 PM   #4 (permalink)
Toystoretom's Avatar
If you can duplicate the no start situation at home you might be able to find the problem.
If you turn on the ignition and the fuel pump runs for a few seconds, by looking at the wiring diagram , it would appear that you are getting power to the starter switch. If the fuel pump doesn't run... email me...
Wiggle the wires to what the others have said while holding down the starter button... you will have to have an assistant hold the button down while you wiggle wires... the kill switch, the sidestand switch, the starter button...
Make sure both headlamps are on, if for whatever reason both headlamps are dark the starter won't operate..
Under the right sidecover are two relays... the one twords the front of the bike is the starter relay. Hold the starter button down and tap on that relay with a screwdriver handle.. if it starts you will need a new relay..
And like tmiller11147 said...check the battery connections, and check the battery itself... it may be failing under a load intermittantly... you can do this by turning on the ignition and observe your headlamps... if they don't come on or are very dim, and later they are bright... this may be the problem..
If none of this helps email me and I will forward you a wiring diagram... if you are no good with those it will be off to the dealer....
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 02-16-2006, 09:33 AM   #5 (permalink)
Thanks for the feedback and advice. I'll start the diagnosis tonight.
</center>
Old 02-18-2006, 05:27 PM   #6 (permalink)
Please let us know what you find. Could be a problem for others. Thanks
biker1059 is offline   Reply With Quote
Starting Problems? patman Daytona Deliberations 6 11-04-2007 10:02 PM
starting problems newrider Sprint Forum 10 11-04-2007 09:31 AM
Starting Problems lhenkel Tiger Workshop (archive) 8 09-15-2006 04:11 PM
starting problems retrobiker Twins Talk 8 10-30-2005 08:44 PM
starting problems carlivar Hinckley Classic Triples 2 01-23-2005 12:04 AM
