I know I know... - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 02-15-2006, 05:00 PM   #1 (permalink)
None of this is Rocket III related but I thought I would share some pictures of my old bikes prior to the Rocket III.
Old Bikes
Rockethead
rockethead is offline   Reply With Quote
Old 02-15-2006, 06:29 PM   #2 (permalink)
Toystoretom's Avatar
That's pretty cool. Is that turbo your design??
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 02-15-2006, 07:25 PM   #3 (permalink)
yes it is, turbo's are not that hard to do...
You need the flow numbers of the motor, the fuel delivery that the stock injectors and pump can handle and then you size the turbo based on your power gains. With the VTX, I had to stay below 10# of boost due to it's compression ratio and I had to install a higher psi fuelpump and positive pressure fuel regulator. The bike went from 89.3HP and 102Torque to 141.8HP and 138Torque at 7psi boost. I gained 5-8mpg at cruising and shaved almost 2 sec. of 1/4mile... all this on $1300.00 out of my pocket!!!
I am planning on using a similar turbo that I used on the VTX, G15 or G16 mitzu turbo with intercooler for the Rocket and pushing 12-15psi boost should be able to give 230-250 HP and Torque, just waiting on the tuneboy software to come out.
Later
Rockethead
Old 02-15-2006, 09:40 PM   #4 (permalink)
I see a stickey in the works.
tmiller11147 is offline   Reply With Quote
Old 02-15-2006, 09:53 PM   #5 (permalink)
Great minds think alike... I had posted that earlier :-D
Even if the tuneboy doesn't show up I can probably get what you need out of the PCIII or even the stock setup. Tuneboy would be better. Somewhere we have a nice clutch upgrade to go with... :-D
Triumph Rocket III
