Help with the OEM Triumph Alarm - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-06-2006, 11:41 AM   #1 (permalink)
Favourite Bike: Rocket 111
Other Motorcycle: Triumph T140V 750
Extra Motorcycle: Triumph Rocket 111
Hi, I wonder if anybody can help?
I have just bought a complete Datatool (Triumph OEM) alarm for the Rocket, can anybody advise where it is fitted, I'm told that it goes under the tank and is clamped to the coil bracket, but I've lifted the tank and it isn't that obvious where it goes, also the wiring??..any help or photo's much appreciated.
Regards
BonnieT
bonnietiler is offline   Reply With Quote
Old 02-07-2006, 12:28 PM   #2 (permalink)
Hi Bonnie.
I have an Acumen alarm on order for my R3.
My understanding is that the Acumen alarm is mounted under the left hand side panel, I do not see why it should be mounted in a different place to the Datatool alarm.
The Acumen alarm is basically the same as for all 2000on Triumphs except the R3 alarm has a longer wiring loom for making the connection under the tank.
I will try to find out more......and come back to you..
TF.
Tigerfeet is offline   Reply With Quote
Old 03-01-2006, 01:26 PM   #3 (permalink)
trumpy81
The Datatool Alarm is mounted under the tank and is held between the frame and number one coil holder bracket.
To gain access to the coil holder mounting bolt you must remove the radiator. Its a royal PIA to fit.
Have your dealer do it for you and save some hair!! :-D
triumph OEM handguards boocat2 Tiger Mods & Bolt-Ons (archive) 10 03-02-2008 11:42 PM
Triumph OEM Panniers gbeasley Tiger Mods & Bolt-Ons (archive) 2 10-01-2007 07:02 PM
Best Triumph OEM parts website? triumphstluster Sprint Forum 3 05-16-2006 06:25 PM
Anyone using the Triumph Alarm ezlee Speed Triple Forum 0 11-06-2004 06:59 PM
Triumph alarm Nomad76 Maintenance & Workshop Talk 12 02-26-2004 08:32 PM
