Tying it down - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleHonda Powersports
Old 02-05-2006, 04:25 PM   #1 (permalink)
I'm awaiting delivery of a Rocket (the only notable accessories being the alarm and a tall sissy bar) and I'm told by biker colleagues that I'll need to chain it to things because people will walk off with it... Sounds impressive, but I guess it wouldn't hurt to buy a chain and some kind of anchor for the garage.
The question is: If there is any point in tethering it, which chain and ground anchor should I buy? At work I'd probably have to attach it to a 12 inch diameter tree: sounds like a lot of expensive chain... I've got a list of "Thatcham approved" devices that make UK insurance cheaper, but there are literally hundreds of them!
Upon peering around the Rocket at the dealers, I couldn't actually see anywhere to thread a chain, and the dealer didn't help when I asked... I'm hoping that threading through the back wheel between the sissy bar and spring should be easy enough, though I'm guessing the exhausts will be hot... Is there a better way?
Do something every day that scares you...
RhinosoRoss is offline   Reply With Quote
Old 02-05-2006, 05:15 PM   #2 (permalink)
The best device that I have seen is the Australian made Taffynackles ground anchor. Taffynackles supply Harley-Davidson these days so you will find them in the Harley catalogue or at most Harley dealers.
There are now a few look-a-like products on the market some of which may be as good but the Taffynackles product has a machined "lid" that covers the dyna-bolt secured base so it is near impossible to tamper with. You attach a chain or other type of security cable to complete the set-up. Davo
Only a biker knows why a dog sticks it's head out of a car window
Aussiebikerdave is offline   Reply With Quote
Old 02-06-2006, 09:13 AM   #3 (permalink)
Not sure how a 700lb bike with steering locked is stolen. I guess you need a flatbed with ramp, a dolly for the locked front wheel and 3 buddies to push it up a ramp.
What's scary in the States is the abundance of Chinese Communist import bolt cutters, in red(what a surprise!) They are cheap, large and at every hardware, auto supply store, shopping mart, etc. I've never seen a chain that a four foot bolt cutter couldn't tackle. Sure the cutters were toast afterwords but the deed was accomplished.
The saying going; " make a thief look like a thief" A person cutting the chain off a bike is an attention getter.
Having said all of the above, it seems the alarm system would be a more than adequate deterrent.
How much does a GPS tracking system cost? That seems the ultimate is crime prevention.
Jeff
Jeff
http://users.shomecom.com/~jeffrey/pics/flag.gif
TRIUMPH ROCKET III ( Latin: Holius Craptor)
Hondax is offline   Reply With Quote
Old 02-06-2006, 10:18 AM   #4 (permalink)
Jeff
No kidding. More like 800 lbs. They'd need a freaking crane.
dougl is offline   Reply With Quote
Old 02-06-2006, 01:07 PM   #5 (permalink)
No way in hell any single thief is gonna make off with a locked Rocket without breaking his back. An alarm system with perimeter/shock alarm is usually plenty adequate to deter all but the pro-thief rings. Nothing is gonna be 100% protection, though. If they want it, they'll get it. Basically, they'll just have a handful of big burly guys lift the bike into a big van and be off in less than a minute with alarm sounding and all. A chain would only slow them down a few seconds.
Chain or disc locks are a pain to use and frankly are kinda dorky. You have to carry a heavy chain around everywhere and you can't always find a place to tether your bike to. Plus it's downright dangerous if you forget you locked up and try leaving.
A perimeter alarm though is also a good deterent against idiots that want to just "test ride" your bike while you're away - the inconsiderate dreamers I call "dry humpers". :razz:
I'm not sure if the Triumph accessory alarm has a perimeter sensor, but I'm sure it has a shock/tilt sensor and will disable ignition when triggered.
I use a full Aritronix Scorpio sr-i500 alarm system with pager and have been real happy with it the last two years. The full system has perimeter alarm, anti-hijack, shock/tilt sensors and of course the two-way pager that'll tell you whenever the alarm is triggered (if you're in signal range). The only thing I don't like about the Scorpio unit is there is no indication that your bike is armed besides the warning chirps and sirens. A flashing LED light would be nice to further deter theives. The Triumph alarm does have a warning LED in the tachometer housing.
[ This message was edited by: RiderRocketman on 2006-02-06 11:15 ]
Ty H. - BPMS RAT Pack Leader (MN) My Photo Gallery
RiderRocketman is offline   Reply With Quote
tying down your S3... dml955i Speed Triple Forum 12 04-13-2007 09:47 PM
Tying down that battery . . . johnquinnell Classic, Vintage & Veteran 3 04-17-2006 11:02 PM
