remove mirrors - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-05-2006, 11:47 AM   #1 (permalink)
Hammer2
Can Some one tell me how to take off the stock mirrors, before I go nuts. I checked in a search, nothing showed up. Thanks Hammer2. :hammer: :hammer:
Old 02-05-2006, 12:01 PM   #2 (permalink)
Toystoretom's Avatar
Don't go nuts...
Look under the mirror mount, there is an allen bolt that threads up into the mirror stem from underneath... a 6 mm allen wrench will loosen it, remove it and then screw the mirror stem out of the handlebar control housing.
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 02-05-2006, 12:17 PM   #3 (permalink)
Hammer2
Tried that the mirrors won't come out and on the front brake side it hits the reservoir and the gas side it just turns, it does not come out. Hammer2
Old 02-05-2006, 03:07 PM   #4 (permalink)
SebringChuck
I tried to just tighten mine up for they kept 'coming in' at speed. All that allen screw on the bottom does is pull the stem down and through the mount until the screw is fully flush with the bottom of the stem. I haven't had them out entirely but it acts as though the stems are just press fitted into the mounts and the allen screw just keeps 'em snug. Looking for some different mirrors that I can tighten on both sides of the mount.
Old 02-05-2006, 04:31 PM   #5 (permalink)
Remove that allen screw and twist and turn or wiggle on the mirror as you pull up on it. It is a press fit into a sleeve that is supposed to help with vibration. If you can turn it you have broken the press fit and you just need to work it out of there. If you have a bunch of corrosion you may need to spray a little rust penetrant down the bottom of the mirror base into that hole. Pull on it like you own it :-D :-D :-D
Ooops... edit... if the mirror keeps turning in you may have to replace the rubber O ring that fits on that allen screw. Its a big fat one that gets crushed sometimes. Without it the mirror doesn't want to stay in place...
[ This message was edited by: Toystoretom on 2006-02-05 14:33 ]
Triumph Rocket III
Old 02-05-2006, 04:31 PM   #6 (permalink)
Hammer2
Thanks for the help I got the mirrors out.. After you get the allen bolt off you turn and pull up. New mirrors on and looking good. Hammer2 :-D
Old 02-05-2006, 08:01 PM   #7 (permalink)
Hammer, what mirrors did you put on? Pictures please. Am looking to do this too.
biker1059 is offline   Reply With Quote
Link for the homemade bar end mirrors from stock mirrors? cf04thruxton Club Cafe' 13 06-17-2008 10:04 AM
Anybody remove this from the exhaust? tsc17 Speed Triple Forum 16 07-05-2006 12:57 PM
Decided NOT to remove AI mecscc Twins Talk 23 06-24-2006 04:58 PM
How to remove DoctorW Speed Triple Forum 3 05-15-2006 11:46 AM
To remove or not to remove? 95bravo Twins Talk 19 03-08-2006 01:55 AM
