changing driveshaft
Hi all, about to change my driveshaft on my '05 R3, the "gaiter" rubber belows between swing arm and motor is glued to the swingarm and looks like it is a snug fit at the motor, the manual says to remove it from the swingarm? From looking at it I would think you should take it off the motor side and pull out the swingarm with it attached. Has anybody done it?
John D.
The examples we set are the lessons we teach!
