changing driveshaft
4K views 20 replies 4 participants last post by  triplestrength
Hi all, about to change my driveshaft on my '05 R3, the "gaiter" rubber belows between swing arm and motor is glued to the swingarm and looks like it is a snug fit at the motor, the manual says to remove it from the swingarm? From looking at it I would think you should take it off the motor side and pull out the swingarm with it attached. Has anybody done it?
#5 ·
Thanks for the advice, it was much easier to take the engine side off. Used superglue to glue the swing arm end and put the driveshaft in from the pivot end rubber boot snapped in with ease.
#6 ·
Now use cupious amounts of Moly60 on th esplines and rear differential. Even add some in the cup of the diferential. I just rolled 60,000 on my Supercharged Carpenter beast and have the original driveshaft and differential. Very few pieces of equipment ever die of over lubrication!!!!!!!
#13 ·
Thought the reason to have a drive shaft on a bike was little or no maintenance.
Sounds to me like a real PITA to pull it apart and grease it.
Thanks for making my mind up to buy the new 1200 Tiger.
Man its less then 15 minutes when the wheel is off to do the job less if you do not drink beer :D
Its Ok the Tiger is a good bike, little putty cat and underpowered but a good bike. Enjoy it.
#11 ·
Thanks JD! Better to be safe than sorry, with the mileage I'm doing I'm getting through a rear tyre every year so the wheel has to come out anyway for that, it's just removing the lower shock mount and the 4 bevel box nuts to remove. Job done, easier than messing with a chain etc.
Sent from my GT-I9100P using Motorcycle.com Free App
#16 ·
My comment on the drive shaft maintenance wasn't meant to degrade the 1200 Tiger.
It was somewhat a surprise to me to already see a discussion on drive shaft maintence
bike hasn't been out that long.
Might consider the bigger Tiger next purchase, so I do like it a lot.
Apologise for any hurt feelings with my last couple posts.
It's fun sometimes to see how some people will get all tuned up and defensive with just a hint of humor about there favourite bike. :)
#18 ·
CB I did not take any of your coment as degrading I just wanted to point out how easy it was to grease the spline on the Rocket I imagine it will be just as simple on the new tiger also. The fact is I have more horsepower on my Rocket then any on the planet and I have been greasing mine with molyKote since the first tire change. I have aquired another differential and drive shaft just in case mine fails but at over 60,000 miles its looking like the little maintenance of lubricating it whenever I change the tire is going to make it last. Granted with all the horse power I have I go thru a tire every 4200 miles and will look at greasing it every two tires now. but my point is very few pieces of equipment ever die of over lubrication :D
The shaft maintenance issue from my understanding is more about prevention than a cure of a problem.
Over the years it seems riders have come to the conclusion that greasing the shaft splines prevents wear.
I personally would rather do a little more than absolutely necessary to avoid issues later. I'm grateful to those riders who by their efforts have enhanced my riding experience and who have been so gracious as to share their experience with others.
And yes I am Very protective about my choice of bike!
But hey this is serious stuff:)
Yes I agree I am protective about my choice and if I ever get something different I will most likely take the manual as minimum maintence required. I will still go the extra as I see fit. This is especailly true when one mods the bike and increases the horse power and torque way above oringinal OEM design specs.
This winter I will be repainting and modifying my other Rocket to 240 hp as she seems weak compared to the Millennium Falcon shown above.
#17 ·
#19 ·
Love the supercharger!
I'm a fusspot and do jobs that don't need doing because I can.
I took most of the switches and electrical connectors apart and filled them with ACF50 grease to prevent water ingress, not a required job by any means but satisfying just the same.
