question about rocket III - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 08-10-2012, 07:18 PM   #1 (permalink)
Main Motorcycle: custom harley
Other Motorcycle: 71 TR6
Extra Motorcycle: varies
I did not post this in the rocket forum, because I did not want to limit the responses...
I am really considering an RIII, but I have a concern bout lean. Will there be a significant torque lean if I hook a small trailer behind it?
I know the old Guzzis had torque lean issues if you worked the engine over.I see the potential for the same issues with the RIII
I am not talking pulling a camper trailer. I am building a small trailer, just large enough to haul a couple guitars, and extra pedal board, and a few extra cords. I want to be able to ride my bike to gigs
Lee H is offline   Reply With Quote
Old 08-10-2012, 07:53 PM   #2 (permalink)
Main Motorcycle: 2003 Triumph Sprint ST
roxynoodle's Avatar
Other Motorcycle: 2008 Ninja 500r (sold)
Extra Motorcycle: 1987 Kawasaki Ninja zx600
If Dog's Bonnie can pull that trailer all over creation I can't see how it could affect a RIII all that much. It will probably barely know it's there.
roxynoodle is offline   Reply With Quote
Old 08-10-2012, 07:59 PM   #3 (permalink)
Main Motorcycle: 71 Bonnie
dogtired's Avatar
Other Motorcycle: 2012 T100
Lee, I don't understand what you mean by torque lean. I am probably being thick here and need it explained in words of one syllable or less.
If you are going to construct the trailer yourself, I have a few suggestions as I have probably put in 20,000+ miles this year towing a trailer behind my Bonnie, so I think I might just have a couple of ideas to share about it.
Construction, hitch type, wheelbase etc.
Tripps has a RIII and regularly pulls a trailer with his, he might be a good source of information as well.
I'd do me...
Deuteronomy 25:11-12
dogtired is online now   Reply With Quote
Old 08-10-2012, 08:03 PM   #4 (permalink)
there is absolutely no question that is has the torque. That engine is a beast. My trailer will not weigh as much as a passenger. My concern is the placement of the weight, being behind the bike as opposed to on top of it, and how that effects a bike that seems to have a tendency to want to lean under acceleration (common issue on bikes with a crankshaft running inline with the chassis, instead of opposed to it)
Old 08-10-2012, 08:05 PM   #5 (permalink)
roxynoodle's Avatar
I think he means he is wondering how much of the power will be lost, Dog.
I've never pulled a trailer on a bike, but I know if I'm pulling something heavy with my truck I turn off the O/D. On a stick I don't use the O/D gear, so it's possible you would want to do the same riding with a trailer.
Old 08-10-2012, 08:11 PM   #6 (permalink)
No, power is not the issue...
Think of your pickup. When you rev it up, it twists to the right. The torque of the engine squats the right side suspension, and the left rises.
The RIII has a engine with a crank running inline with the chassis. This can make the engine want to rotate to the right side, and the rider must compensate. I want to know how much more it will "twist" if a weight is behind the bike, as opposed to a passenger acting as ballast
Old 08-10-2012, 08:15 PM   #7 (permalink)
roxynoodle's Avatar
Ok, I know what you're saying. It isn't something you feel as much on my truck, but I had this 85 Chrysler Laser when I was in college that did it badly enough that I wondered if the engine was too powerful for the frame. I used to worry that I could twist it.
Old 08-10-2012, 08:28 PM   #8 (permalink)
The old dodge muscle cars had an extra leaf spring on the right side if you got one with the "track pack"
Old 08-10-2012, 08:34 PM   #9 (permalink)
LEE
Main Motorcycle: RIII
LEE's Avatar
Seven Years on the Rocket III and many many miles there is no lean unless you engage it going into a twisty...if any bike can pull a trailer big or small it is the Rocket.
LEE is offline   Reply With Quote
Old 08-10-2012, 08:36 PM   #10 (permalink)
Junipero's Avatar
Other Motorcycle: 2011 BMW R1200RT
My RT1200 does that Lee. I know what you mean now. But I can't figure out how pulling a trailer would affect it any more or less...at legal speeds anyhow.
"The views expressed here are my own and do not represent my employer's position or opinion."
Junipero is offline   Reply With Quote
Question about Joe Rocket mkI Riding Jackets/Pants 2 04-17-2012 11:03 PM
Rocket Roadster tank pad question bondage007 The Rocket Science Forum 2 09-17-2011 01:08 PM
PC3 05 ROCKET 3 Question markn2147d The Rocket Science Forum 6 09-19-2009 08:51 PM
Replacing Rear Brake Pads on Rocket question gsmitty The Rocket Science Forum 8 07-18-2008 02:42 PM
Not really a rocket science question but... AdmiralRocket The Rocket Science Forum 5 12-30-2005 08:43 AM
