R3 Engine Question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-16-2012, 03:45 PM   #1 (permalink)
Main Motorcycle: 1970 Triumph TR6R
McBike's Avatar
Other Motorcycle: 2007 T100
Extra Motorcycle: 1969 Bonnie Basket
R3 Engine Question
Looked at an R3 Roadster at my local dealer on Saturday. He was telling me that the engine has a dry sump and an oil tank. He then said that the engine shares the oil with the transmission. Can someone please explain the setup as to how this works? My assumption is that dry sump = seperate transmission oil.
Thanks
Mike
2007 Black / Red T100 AI removed, Hella H4 "E" Class Headlight, Feked Toga style mufflers 118 mains 40 pilot 2 3/4 turns out, Dual Star heated grip kit.
First Bike: 1966 Yamaha YL1 Twin Jet
The older I get, the faster I went.
McBike is offline   Reply With Quote
Old 04-16-2012, 08:30 PM   #2 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
The salesman was quite correct. The reason for a dry sump is to get the engine and gearbox as low as possible which in turn lowers the C of G. There are 3 drain plugs to drain the oil from the engine sump, oil tank and rear sump. My understanding is the oil is pumped from the sump up to the oiltank it's then pumped to the engine & gearbox before returning to the oiltank. Capacity after an oil & filter change is about 6.5 litres. The only other oil container is the final drive on the rear wheel.
Sent from my GT-I9100P using Motorcycle.com App
triplestrength is online now   Reply With Quote
Old 04-17-2012, 07:39 AM   #3 (permalink)
McBike's Avatar
Thanks for the clarification, I knew that it was a dry sump to get the engine lower. Just didn't know how the engine and transmission shared the oil. I just assumed that they were seperate.
Mike
Old 04-23-2012, 10:54 AM   #4 (permalink)
Main Motorcycle: 06 Rocket Classic
Other Motorcycle: 05 Rocket
Mike Triple is right and the oil pumping thru the trannshaft feeds the inside of the wet clutch. There is also a external line spraying the outside of the clutch basket. then runs down to the sump where the scavenger pump send it back to the tank. The bike has two pumps scavenger (low pressure) and the high pressure feed pump.
warp9.9 is offline   Reply With Quote
900 engine question DCM Trophy 15 10-17-2008 10:04 AM
Engine question from a new guy Torque addict Sprint Forum 44 06-29-2008 09:30 PM
Engine Question SoCalSprint Sprint Forum 5 08-03-2006 07:43 AM
Question about Engine oil / Engine Covers on a Bonnie..... Brk4moose Twins Talk 6 05-31-2006 09:48 PM
question engine mod??? tmo Twins Talk 4 10-17-2005 11:45 PM
