Old 11-12-2005   #1 (permalink)
humble
just rode home my 2006 rocket! read the cat box thread about the "C or Z"...guess what? i have a r6rut&%$!!! C!!
what now? any way around it? i live in florida, any help would be great. oh yeh and by the way...the dealer told me "dont worry, no difference between the 05 & 06...jeeeesh.
Old 11-12-2005   #2 (permalink)
All Rockets now come with a full catbox. Cheapest way around it is get the catbypass pipe or what Triumph calls the silencer upgrade kit. Last I remember it was $350 USD. That'll up your stock pipes' sound and give a bit more power.
More expensive way around it is to replace the entire exhaust system with an aftermarket solution like the Jardine 3 into 1, but when selecting one make sure it replaces/throws out the catbox instead of connect through it.
Ty H. - BPMS RAT Pack Leader (MN) My Photo Gallery
RiderRocketman is offline   Reply With Quote
Old 11-12-2005   #3 (permalink)
humble
RiderRocketMan...........THANKS!! I was thinking i got stuck! I will do the bypass surgery ASAP! i guess this should up my HP also? :-D
Old 11-12-2005   #4 (permalink)
Many of us with the N catbox removed it pronto, a C catbox should be trashed at the earliest opportunity.
What a long strange trip it's been
Valkyrie111 is offline   Reply With Quote
Old 11-12-2005   #5 (permalink)
humble
Well...Powerbike....do I just bypass it....or completely throw it out?
Old 11-12-2005   #6 (permalink)
Well, if you "just throw it out" you might as well throw out your pipes too since they'll no longer be connected to the headers! :razz:
Old 11-13-2005   #7 (permalink)
Humble, your other options are Thunder pipes sold in the states through 'newr3' or 'Staintune', which make a stainless three into two or three... Also with a stainless collector which replaces the cat. AussiebikerDavo of this very Forum manufactures the Maddog pipes which can be utilized with the Triumph cat replacement.
My advice is to fit a PCIII with whatever upgrade you chose to maximise the HP and smooth out the delivery and get rid of any decel popping.
Then of course replace the stock rear shocks :-D
Red
SteveRed..
He said... "Nobody needs that much power"
I said... "Who wants to be a nobody?"
SteveRed is offline   Reply With Quote
Old 11-13-2005   #8 (permalink)
Hello humble, you have to remove the catbox in order to install a bypass. Real easy job, if you do a search on the forum you will find lots of information.
Old 11-13-2005   #9 (permalink)
Favorite Bike: 06 Speed Triple
Other Motorcycle: 05 Rocket III
Extra Motorcycle: 03 Warrior
I don't think I would bother with the by pass pipe for $350.00 . I bought a set of D&Ds for $ 500.00 and they do away with the catbox and give a nice tone too .
Life is a highway Enjoy your ride
Photo Album
rockt3 is offline   Reply With Quote
Old 11-14-2005   #10 (permalink)
humble
Thanks everyone for all the help.....I called my dealer..........he said......"no problem, just come in for your 500 service and I will swap out yours for one with no cat"
is that worth doing, or should I just pass? As I understand it now, I CAN eliminate the box, but will have to get after market setup of some kind......because the box is actually part of the exhaust now...........makes sense.
Thanks again....................oh yeh...........part of the "dropped a Rocket" club now..............jeeeesh...........and I told my wife, the limp was because my boots hurt! :wink:
removing pre-cat and cat on '07 S3 jpeake Speed Triple Forum 23 05-17-2007 11:12 AM
Cat on the Tiger? rew7602 Tiger Workshop 4 01-12-2007 05:34 AM
Which Cat Bypass to Get ??? RatBoy The Rocket Science Forum 8 11-08-2006 04:41 PM
CAT PY-PASS Mitch The Rocket Science Forum 1 06-07-2006 04:14 PM
i'm a cat tango Tiger Chat 14 10-31-2003 08:15 PM
