Second on Garys' post. We put gas and water in 2 clear bottles. In one we added methanol based dryer and isopropol based in the other and shook them slightly to mix. Within 15 minutes the water and gas started to separate in the methanol bottle, after 24 hours had layer of gas on top of water. After 24 hours, the contents of the isopropol bottle stayed mixed, the water would burn off with the fuel.
Check fuel tank vapor lines (2) on left bottom side of tank to see if they are pinched between tank and rubber cushion on frame. If pinched they will not allow water to drain from filler area, when you open the cap, water drains into tank.
Ride hard, die old.
