I figured it would be easier to let the ECM think the plates are still there, than to change any input signals. When the plates are removed, the servo motor and position sensor (encoder) for the secondaries are still operational. I have no idea of what other operational parameters would change if you told the ECM that it was not in 1st or 2nd gears (mixture, timing advance, etc.). I observed that the secondaries opened on cold start indicating they do not have any "choke" effect. The only trick I found is to adjust to very slow speed manuvering and cornering throttle operation. All in all it's an easy mod that gives you quicker throttle response in 1st - 3rd gears. It gave my bike what I felt was missing when I first bought it, even after cat box removal, TORs, and 20056 tune.
Ride hard, die old.
