Old 10-01-2005   #1 (permalink)
Toystoretom's Avatar
This looks ver familar:
Eastwood - Painless
This might be an easy swap....
You should check out the rest of the Eastwood site... Lots of good stuff there. Order a catalog
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 10-01-2005   #2 (permalink)
Tom, the LED's won't fit in the r3 housing, "cause it doesn't open. AAAND, the featured tail light is waaay too small for the r3 opening. That lamp is pretty small.
Ron
Aussiekeeper is offline   Reply With Quote
Old 10-02-2005   #3 (permalink)
Oh Oh... Am I going to have to do the old ship in a bottle trick???
Triumph Rocket III
Old 10-02-2005   #4 (permalink)
If you want LED's, go to spider lights. They are LEDs that are on arms. You stick them in the original hole and the arms open up and fill the lamp housing with light. They are brighter on both the running mode and the brake light. Also are omni-directional.
Ron
Old 10-02-2005   #5 (permalink)
That IS the ole' ship in a bottle trick...
Where would I find these spiders :???:
Triumph Rocket III
Old 10-03-2005   #6 (permalink)
Favorite Bike: Rocket3
Other Motorcycle: Yamaha Royal Star (96)
Forum;
Spider lights...
http://www.customdynamics.com/spider_led_lights.htm
Charles
Henryville, IN
Royal-R3 is offline   Reply With Quote
Old 10-03-2005   #7 (permalink)
Hard to believe that it's already been a YEAR since I opened up my tail light and installed a 128-LED board from Radiantz.
You want bright? This sucker is BRIGHT and looks stock...until you hit the brakes.
ChipmunkBob
\'52 DHC-1 Chipmunk
\'05 Rocket III
Chippie1 is offline   Reply With Quote
Old 10-04-2005   #8 (permalink)
Chippie1;
Which model / part no did you order. I see the ones for Honda's 9012-11 for VTX/Shadow, Ace, et; 9013-11 for VTX 1300-1800 both of which have 128 led's as indicated in your note below.
Charles
Charles
Henryville, IN
Old 10-05-2005   #9 (permalink)
Hey there,
I originally had this on my VStar 1100. It is kit 9011-11. It has a standard plug-in pigtail. No modification to the wiring needed. A bit of "Dremel artwork" is needed on the housing though, and I noticed on the website that it looks like you have to buy the whole taillight assembly (including lens). When I bought mine they sold the board separately and you replaced the guts of your taillight (minor work). It was a lot cheaper back then. I guess now you would have to buy the whole thing and remove the board? Looks like it's just screwed down with 2 screws.
I tried to take some pics a while back and they turned out bad. I guess LEDs don't photograph too well, despite the fact that I kept telling them they looked marvelous...
Anyway this is definitely a worthwhile mod.
ChipmunkBob
\'52 DHC-1 Chipmunk
\'05 Rocket III
Old 10-06-2005   #10 (permalink)
Hey Chippie do you have a web site or link??
SteveRed
SteveRed..
He said... "Nobody needs that much power"
I said... "Who wants to be a nobody?"
SteveRed is offline   Reply With Quote
LED Tail Light Bulbs Will Modifications & Workshop Talk 9 02-23-2008 01:36 PM
LED Integrated tail light Q? whoosh Sprint Forum 12 08-21-2007 02:24 PM
LED tail light conversion TBS-cafe Hinckley Classic Triples 14 04-10-2006 11:24 AM
Tail/Brake light LED RicoSuave The Rocket Science Forum 17 11-06-2005 03:57 PM
Custom LED Tail Light kuhlka Speed Triple Forum 24 02-19-2005 11:49 PM
