BikeBandit
Old 09-25-2005   #1 (permalink)
glw
Favorite Bike: Rocket III Classic
glw's Avatar
Other Motorcycle: 76 Bonneville
I have the Harley oil temp dipstick and my r3 seems to run around 190-200 degrees, i am in Florida so its been in the 90's.
Was wondering where the normal range is for this bike..200 seems a little high but maybe not..my brothers hd runs around 165-180 degrees.
Wondering if the guage is not accurate, since the fan is supposed to kick on i think around 185 and thats not really happening that often.
glw is offline   Reply With Quote
Old 09-25-2005   #2 (permalink)
Toystoretom's Avatar
The cooling fan works on a sensor that senses coolant temp... not oil temp. I just looked through the service manual and it doesn't give a spec for what coolant temp the radiator fan kicks on ( at least not that I could find in the cooling section of the manual). Usually the fan will kick on at 220 F or maybe even higher. If you have an OBD II scanner you could hook it up and observe the coolant temp when the fan kicks on.
We have had some reports that if you get your Rocket really hot the ECM will shut the engine off to keep it from seriously overheating.
Tomo
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 09-25-2005   #3 (permalink)
glw
glw's Avatar
Good point.. dont know why i was thinking the oil had anything to do with the cooling fan.. i dont think its running hot just wondering what the norm is.. thanks TST.
Old 09-28-2005   #4 (permalink)
I think I read in the owners manual that the fan went on @ 210 and shut off @ 180.
Ron
Aussiekeeper is offline   Reply With Quote
engine back fire, normal? kidkazi Twins Technical Talk 16 06-21-2007 10:32 PM
engine temp bad406 Sprint Forum 7 04-08-2007 04:26 PM
Engine temp? Ozz Triumph SuperSports 3 09-17-2005 04:00 PM
normal operating temp? texastrip Daytona Deliberations 4 11-08-2004 01:32 AM
What is a normal engine temp? Sprint Forum 6 05-24-2004 03:28 AM
