AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 09-23-2005   #1 (permalink)
Has anyone else had this problem? It sounds like it's coming from the engine. Our guess is that it's either valves or an exhaust leak. I'm leaning towards the exhaust leak as I just had a valve adjustment with my 10K service!
My dealer hasn't been much help and has told me "live with it, it's the nature of the beast). That's b.s. as I've not heard this noise from any other Rocket.
Any ideas?
Slick is offline   Reply With Quote
Old 09-24-2005   #2 (permalink)
I test rode a Rocket today and it had the same thing. I told the dealer about it, he started it up to have a listen and it wasnt there. :razz:
Bikernoob is offline   Reply With Quote
Old 09-25-2005   #3 (permalink)
Toystoretom's Avatar
Noises suck.
You can use a rubber hose as a stethascope to find the general location of the noise.. you can also use a long handled screwdriver... put the metal blade on the engine and hold the handle to your ear. You will be amazed at how well this works.
My bike will tap at certain times but it comes and goes. It doesn't happen very often... sometimes after a long hard run on the interstate. It sounds like valve train stuff but who knows. It could be anything. As you can tell... I don't worry about it because it happens infrequently and its not very loud and it doesn't get worse.
If it is an exhaust leak the rubber hose method will expose this quickly...
Tomo
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 09-25-2005   #4 (permalink)
When I first start up my bike in the morning it makes a marble in a can rattle at exactly 1500 rpm.. This lasts until the bike warms up a little.
As long as it does not get worse, I won't bother with it...just consider it part of the character of the bike.
Maybe the bike wonders what strange noises come out of me...like singing and......ahem.....farting. Its a two way steet I guess.
Ugarte is offline   Reply With Quote
Old 09-27-2005   #5 (permalink)
I used to have this same problem with mine. I'd be sitting at stop light and would hear all these stranger noises coming from the engine. Couple times I would even take off my helmet for a closer listen. Well I can't tell you what the noise is but I don't hear it anymore. All you have to do is buy the TOR system with the CAT bypass and "poof" it's gone!
Drech - Drive fast, take chances! :)
Dresh is offline   Reply With Quote
Old 09-28-2005   #6 (permalink)
Ugarte, mine does that too, in the 1500 rpm range. Pretty loud in fact. Lessens when it's warmed up. The part that bugs me is that it never did it till it turned over 10K miles. I'll have it checked out when I take it in for the valve check and speedo replacement.
RocketEd is offline   Reply With Quote
Old 09-29-2005   #7 (permalink)
Dresh,
I already got rid of the cat box! It's loud enough that it's driving me crazy! Tick, tick, tick..... you get the point.
I'm probably going to call corporate to ask for a regional rep to check it out.
Old 09-30-2005   #8 (permalink)
I just noticed mine doing it and at about 1500 rpm and stop around just under 2000. I pulled into my garage and got off the bike and knelt down it sound like it is coming from the front lower near the water pump.
choochford is offline   Reply With Quote
Old 10-03-2005   #9 (permalink)
Favorite Bike: R90/6 BMW
At 3000 miles mine broke down - expect it to be a roller cam chain or some such. Was making the exact same noise as described. The bike was running strong - in middle of 600 mile day when it broke.
TallRocket is offline   Reply With Quote
Old 10-05-2005   #10 (permalink)
Update - the Allan head bolt on the cam roller guide appears to have backed out. The shop listed several related parts that appear to require replacement. They promised to contact Triumph HQ to see if they should continue the disassembly process and check for valve damage.
Ticking Noise coming from Engine revolve99 Speed Triple Forum 3 10-03-2005 12:51 PM
clicking/ticking engine noise Slick The Rocket Science Forum 2 10-03-2005 09:34 AM
ticking noise hinkleyboy Triumph SuperSports 5 09-10-2005 01:56 PM
Clicking Noise from Countershaft area RalphS Sprint Forum 0 08-28-2005 08:45 AM
clicking noise when hard braking and downshifting punisher Triumph SuperSports 4 07-18-2004 01:11 PM
