Transmission grinding - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-19-2005, 07:59 PM   #1 (permalink)
Wondering if you guys have experienced any problems with your transmission making any type of grinding noise. My Stepdad picked up his Rocket from the Triumph dealer the other day after having the timing chain guide replaced, now it is making some scary noises that appear to be from the tranny. If the clutch is in and you rev the motor everything sounds great, put it in gear and start moving and there it goes. Is this a problem anyone is familiar with? Any thoughts? thanks Fbird
99TBS and 2000 Sprint ST
fbird is offline   Reply With Quote
Old 09-19-2005, 08:26 PM   #2 (permalink)
Just got my bike back on Saturday with a new bearing at the rear of the tranny where it joins the driveshaft. I have heard of several people having this problem. Sound rough and changes with the speed of the bike not the motor. rolling along with the clutch in and the motor idling sounds like a bag of gravel in a tin can.
I hate this Guinness, I'll be glad when I've had enough!
rocket3sum is offline   Reply With Quote
Old 09-19-2005, 09:49 PM   #3 (permalink)
Rocket3sum, I'm glad it's now fixed and you're back on the road.
Three questions: Did they replace anything else other than the bearing? Did they give you any assurances that this would not happen again? Did they say that the new bearing was up-graded, any different, stronger perhaps?
Davo
Only a biker knows why a dog sticks it's head out of a car window
Aussiebikerdave is offline   Reply With Quote
Old 09-20-2005, 07:38 PM   #4 (permalink)
A couple of things make me nervous about this repair. I was told that Triumph considers this bearing failure to be, "not the norm" yet they decided to send a "replacement unit" whatever that is, instead of the bearing, seals etc. that the dealer ordered and I have heard of several others with the same problem. No idea if the bearing unit was an upgrade
Old 09-20-2005, 10:15 PM   #5 (permalink)
Toystoretom's Avatar
I wouldn't get too wiggy wiggy over Triumph sending out a unit instead of seperate parts. I'm in the car biz and this is becomming quite common. Some of it has to do with the available equipment at different repair shops. This bearing may need to be pressed in using special adaptors that many shops don't have. To ensure a complete and consistant repair in an area that may be a trouble spot they choose to replace the assembly.
Just as long as it gets fixed... right???
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 09-23-2005, 09:46 AM   #6 (permalink)
fbird- what's the latest on this situation?
Tomo, I agree, Triumph has the right idea on replacing it as a unit IMO, clearances are very critical here.
Davo, I too was wondering if there was an upgrade yet. The failed one that I saw was COMPLETELY destroyed. Triumph is asking a lot of this part and I would think it is very susceptible to side load, what with 147ft.lb. twisting it on one end, the torsion spring varying length under load, the swing arm going up and down on the other end and the loose nut at the 'bars trying to perfect getting second gear rubber.
Do many other bikes use this method of shock absorption?
RocketEd is offline   Reply With Quote
Old 09-23-2005, 02:35 PM   #7 (permalink)
Hey Guys,
No info on the problem yet. Triumph picked up the bike yesterday afternoon. Hopefully I'll have an update later on. My Stepdad is really dissappointed, he just got the bike back after a month in the shop. He had the full power tune installed while it was there and it was runnin awesome, now this. I'll let you know what happens. Fbird
Old 09-23-2005, 11:04 PM   #8 (permalink)
fbird,
I had my ride down for 35 days and now its dropped a jug!
The repair was not done right the first time with my bike!
rockenrobert
gotta see the world, it will only take a minute
rockenrobert is offline   Reply With Quote
Old 09-30-2005, 10:58 PM   #9 (permalink)
Rod
Samething happened to my bike. They replaced the bearing, and everything behind it. Running fine now but hope it doesn't happen again.
Grinding toes rodsprint Sprint Forum 26 01-13-2008 06:27 PM
Scraping/Grinding Noise? Legman Speed Triple Forum 7 11-06-2005 07:09 AM
Grinding the pegs yes but grinding the exhaust? tazwolf Hinckley Classic Triples 17 10-01-2005 09:34 AM
grinding first gear lipmorg Classic, Vintage & Veteran 8 08-15-2005 12:59 PM
Grinding cluch TriRider Trophy 8 03-12-2005 05:14 PM
