Hello folks,
i have the Corbin seat, (as a replacement to the gel seat) and believe it was a good switch. just like you, my backside was numb on the gel w/in an hour. i don't have this problem with the Corbin. The Corbin seat installation does NOT allow you to use the key access to under the seat.
FYI...if you go with the heated seat option, make sure you brainstorm on alternative installation options. My shop did the install and did it according to the instructions and it's a messy setup to say the least. Cutting the fuse box, using velcro...a mess. the integrity of the fuse bow is completely compromised and I will have to get in there and change it completely around. haven't done it yet...got pissed off, put the seat back on when i saw it!
i have been looking at the Wilbur shocks (as recommended by some of the owners on this site). I have the Corbin hard bags and need to figure out which model will work with this configuration (the 630's or 633's...i have pictures of both but can not seem to load them up on this post...). I would like to go with the 633, due to the adjust-ability, but need to be sure they will fit with the bags...any body have this setup. The current setup does NOT work with my girl at all. 70 mph on the highway and you hit a bump and she feels like she's going to bounce into the median. I need chiropractic treatment after a 2 hr ride.
I am hoping that the combination of seat and shock modification will work.
Cheers,
MCJ
nullnull
