I had a small leakage from top bolt on water pump bike 3 months old. Found all the bolts on water pump not torqued to my likeing. Also found 2 spark plugs done up finger tight. After reading about a guy that exhaust fell off have since gone over every visible nut and bolt and firmed up to respectable level with spanner with 6 inch handle. I strongly recommend you do the same. A lot of nuts and bolts not torqued sufficiently for vibrating motorcycle.
Go Hard or Go home!
