Joey...
I went down and looked at mine (I haven't changed out an oil tank) and it looks dismal. You could try loosening both of those long bolts as far as possible and see it the tank will tip out far enough to loosen them completely, then pull the tank out with the bolts still in the tank. You may have to loosen the three small clamps that hold the throttle bodies to the head so you could pull that assembly up a tad. Remove the chrome bear claw so you can get in there and work. If this doesn't do it you will probably have to pull the whole thing apart. You may have to anyway... just to get to the hoses back there.
Yikes....
Tomo
PS... on page 9.16 of the service manual it says to remove the throttle bodies....
[ This message was edited by: Toystoretom on 2005-09-05 21:18 ]
Triumph Rocket III
