Motorcycle.com
Old 09-01-2005   #1 (permalink)
Info in the FAQ sticky suggests that the V rated front tyre "will not match" the V rated rear tyre.
While this may be technically correct, the difference in the stength of two tyres is minimal.
The "H" tyre is rated for continuous operation up to 190kph (118mph) and an outright operation of 210kph (130mph).
The "V" rated tyre is rated for continous operation of up to 210kph (130mph) and an outright operation of 240kph (140mph).
I have an "H" front tyre fitted because the importers were out of stock of the "V" rated tyre and I've got a long ride coming up. There is no difference in look, feel or handling but I guess I wont be able to travel at any more than a constant 190kph anymore. Bummer!
Davo
Only a biker knows why a dog sticks it's head out of a car window
Aussiebikerdave is offline   Reply With Quote
Old 09-01-2005   #2 (permalink)
Davo,
Given that those are the standards for the tires, I'd bet my pink slip that there's a fudge factor built in - you can probably ride 140mph all day on that H rated tire.
RickL
RickL is offline   Reply With Quote
Old 09-01-2005   #3 (permalink)
On 2005-09-01 20:54, RickL wrote:
Davo,
RickL
Not really an issue in the USA.
It's not the destination, but the journey there that refreshes the spirit.
HDGoose is offline   Reply With Quote
Old 09-05-2005   #4 (permalink)
Not with me on it..............
Ron
Aussiekeeper is offline   Reply With Quote
Old 09-05-2005   #5 (permalink)
Heat build up is the main issue. To oversimplify the subject there is a flat spot at the bottom of the tire known as the footprint. At high speeds this area has to take the shape of the road and then go back to being round. This flexing a:causes heat.
b: takes time.
The faster you ride the further around the tire for the shape to recover which can lead to nasty things happening such as,in extreme circumstances, a second ripple before the first has resumed normal shape. I suspect that the difference between a V and H rated tire would be close but you would be betting a lot more than your pink slip if you decided to prove conclusively one way or the other.
I hate this Guinness, I'll be glad when I've had enough!
rocket3sum is offline   Reply With Quote
horsepower rating?? subarutech77 Twins Technical Talk 6 06-25-2007 05:27 PM
rating suppliers beegee Classic, Vintage & Veteran 7 10-06-2005 07:19 PM
speedmaster HP rating question dazco Modifications & Workshop Talk 1 07-31-2005 09:50 AM
Alternator rating on '05 ggRAT Sprint Forum 1 07-05-2005 07:11 PM
Which octane rating for '05 s3? Big_Guns Speed Triple Forum 13 06-01-2005 03:55 PM
